Warning!! Chrome goose necks!!
Just wondering what you guys are talking about, i saw chrome and came running
ZD
This is definitely not my area of expertise, but another forum member pointed out that if you have your engine grounded in a certain way, the coolant causes an interaction between the iron/steel and the aluminum... similar to the sacrificial rods in electric water heaters... and the aluminum is eaten away. This affects all aluminum on the engine, not just the water outlet. Maybe you have this problem?
Again- not my area of expertise... another forum member was way more educated on this topic than I am.
Just a guess.
It was chrome but didn't leak any water,I left my bike out in the rain and the handle bars filled up with water and then they leaked,and they were chrome!!!
I've had a Mr. Gasket chrome T-stat housing on my Z28 for the past 1 1/2 years. No problems so far. Actually bought an identical housing for my Vette but haven't installed it yet. H-m-m-m-m-m. Makes me thing. What kind of antifreeze are you using, and do you add anything like Water Wetter.
Unfortunately, Mr. Gasket has bought up a lot of other once reputable aftermarket companies and applied the same operating principles to turn them to crap too. The only appeal that I can see that they possibly have is the cheap price, but beware, it could cost a lot more money in the long run because you'll have to fix it twice.
ZD
P.S. I use Moroso rubber on metal frame valve cover gaskets and Fel Pro elsewhere. The only place I got Mr. Gasket showing is on the PVC breather and beleive me, I'd PREFER not.
[Modified by 79MakoL82, 11:17 AM 11/6/2001]
Hans
i used to use distilled water,but a friend of mine(certified mech) advised me to save my money(i know we're not talking big $$$ here) and flush the system and use new anti-freeze every year,2 years maximum.
who's got ground straps on their engine??? i don't and haven't seen a vette with them,unless they're in some hidden area.maybe my engine is not grounded properly.
BTW, the mr gasket goose neck is not aluminum,it's cheap "pot" metal,thin to boot. it looked good and sealed fine,it was just a member of the NFL (not for long) club.
Again- no expert in this arena, but I believe someone else said a lack of proper grounding can contribute to corrosion.
I also use tap water. I know distilled is the perfect, correct thing to do, but tap water has sufficed so far.
I do a lot of road trips and distilled water is not always available when I need a fix... so using distilled water for me would be a waste of time since I'm ultimately going to be forced to top-off with tap water eventually. Based on experience with my "driver" cars (not my 66), changing out the coolant every 2 years should be adequate for corrosion resistance. However, mineral content/buildup may be a different story. Distilled water is probably the only solution for that problem. I guess it would depend on the actual content of your tap water.
