cam
Old Nov 6, 2001 | 08:21 AM
HarleyBob's Avatar
HarleyBob
Default cam
Question
Have an 82 CE with straight duels (no cats) and Flow masters #40, with K&N Filters.
Would I realize any great improvements if I changed the CAM and if so what CAM?
Want just a little more umph!
Old Nov 6, 2001 | 08:28 AM
Paul 75 L82's Avatar
Paul 75 L82
Default Re: cam (HarleyBob)
For Sure, The Comp XE262 probally would be a good choice for you. Great low end power, nice lope.
Old Nov 6, 2001 | 01:40 PM
UKPaul's Avatar
UKPaul
Bob,
Yes you should notice a difference with a better cam. I assume that your car is computer controlled like mine (except you've got injection & I've got a carb)? Crane do a series of cams (2010, 2020, 2030....) that are designed for use with computer controlled vehicles. They give different durations/lift for the inlet/exhaust valves. The inlet valve is controlled in such a way as to keep a high manifold vacuum (no lope) so that the computer is happy with it. Worth a look :)
:cheers:
Paul
To cam
