Is this normal for Half Shafts?
) While I had the trailing arms out I was checking the half shafts and the passenger side slid out of the differential almost by itself... so I thought I'd take the opportunity to clean them both up before I put the trailing arms back. The drivers side is a different story it does not pull free from the differential like the passenger's side did. Was there something missing from the passenger side that allowed it to pull free like it did? The yoke(?) does not have any signs of damage and slips back into place just as easy.. is there something missing here?? Houston, do we have a problem?
Thanks guys!!
Thanks guys!!
The yoke may only have a limited amount of play. The half shaft also acts as an upper suspension arm.
Check out the differential post of GTR1999 (Gary) or give him a PM. He is the expert on them here and a good guy.
I guess you're in for a rebuild.
As already mentioned, the circlip is either worn off or just fell off.
Look at the pics of the yoke in catalogues and compare to what you have. There must be a groove on the end for the clip. If there is not groove anymore, the yoke is worn off. If there is still a groove, the cirlip fell off.
In both cases, you need to opene up the pumkin rear cover, insert the old yoke and reinstall the circlip or if it is worn, insert a new yoke.
With some luck, nothing else is damaged inside the differencial and all it needs is new oil & additive.
And if one side is so worn, the other side will be very simmilar. Hence, if the groove is missing, buy a set ( 2 each ) yokes and circlips.
Good luck. Günther
Time to brush up on differential rebuilds, check those posts by GTR1999 and see if this is something I should attempt myself. For anyone whose already tackled a rebuild, is this something a 'yank-n-replace' mechanic like me should try? Who has good rebuild kits?
I'll also try to get some pictures of the yoke for a reference...
Thanks again guys!
Rick B.
Thanks again guys!
My advice is to rebuild it completly. If you see how difficult it is to remove the pumpkin alone, it is better serviced now than later.
The advise for a rebuilt is surely good, but I know how someone feels about this, specially because this wasn't planed.
If you remove the differencial's cover ( also some work because the aft spring must be removed ) and look inside, you can see what exactly is required. No debris, no damage etc might not require a complete rebuilt, but just a new yoke inserted and circlip installed. This can be done by just about everybody who manages to get the differncial cover removed.
Lets see the pics of your yoke and also inside of the differncial once it is open.
Günther
