Removing Brake Booster
Old Aug 19, 2007 | 11:36 AM
Stavros's Avatar
Stavros
Default Removing Brake Booster
I finally have pulled the engine out..... The first strain of the "while you are at it" disease has begun. The leaky power brake booster.
Any special tools or recommendations on removal other than lots of u-joints and a pillow?
Old Aug 19, 2007 | 11:41 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
There is no easy way to do this but there was a post sometime ago with some insight to the job. Do a search for it.
Old Aug 19, 2007 | 11:43 AM
dannyman's Avatar
dannyman
Remove drivers seat and crawl into the car.
Old Aug 19, 2007 | 11:46 AM
sly vette's Avatar
sly vette
Since you got the while I'm at it bug.....Pull the dash and replace the interior!!!!!
Old Aug 19, 2007 | 12:52 PM
Durango_Boy's Avatar
Durango_Boy
As mentioned above, pull the seat. You will be very glad you had a long flat surface of the cabin floor to lay on upside down with your head under the dash. That being said, I found a small throw pillow or a folded up towel worked very well to keep my head comfortable and my neck supported.
Comfort is key here so you don't lose patience and throw something.
Dissconnect the master from the booster but you can leave the lines attached to the master. Remove the vacuum line and then move inside.
You'll have a fun time removing the clip that holds the pedal rod pin in the pedal arm. I managed to get it off with a flathead screw driver but sometimes needle nose pliers will make short work of it.
Have an assortment of tools ready. You'll want a deep wall socket, wobble if you have one, or a spring loaded joint will work too. Have lots of extensions ready or one really long one.
Then the ratchet. Once you get all four nuts out, the booster is ready to be pried away from the firewall.
Are you replacing it because it's bad or upgrading to something else? If you're taking it out why not upgrade to hydraulic power brakes that run off of your power steering system?
Old Aug 19, 2007 | 01:10 PM
dannyman's Avatar
dannyman
Any chance you have a stubby ratchet wrench? That one tool will save much aggrevation!
Old Aug 20, 2007 | 02:43 PM
VCuomo's Avatar
VCuomo
(I use one with a swivel handle).
And it ain't removing the clip that holds the pedal rod pin in the pedal arm that's a pain (if you use needle-nose pliers) - it's getting it back on!
Old Aug 20, 2007 | 02:48 PM
Durango_Boy
And to that I would like to add that if you get that clip off and the pin out...when you reinstall the clevis you should install a pin with a cotter pin instead of the stock one.
Several vendors sell the updated easy pin.
Old Aug 20, 2007 | 05:48 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
It's not too bad if you pull the driver-side dash...
To Removing Brake Booster
