Hi-revving small block
A wheelbarrow full of money makes anything possible.
-Mark.
My combo is :
- 400 sbc
- 3.250" stroke steel crank
-6.250" steel oliver rods
- je pistons with 10/1 CR
- dart pro 1 aluminum 215
- crane mech. roller cam (278/288 + 246/256 @0.05 and 0.63" lift
- normal 1 3/4" headers
- soon to be fitted with an 8 tb manifold and efi.
- valve springs 1.550" with 220 closed and 500 open
- revkit
- stud girdle.
If you take care in selecting the right parts for the combo, you can have relatively good low power and still can go higher in the rpm's. A lott depends on the airflow through the engine.
I feel that 7000 rpm is a critical limit in cam selection.Going higher would require longer duration and would mean a higher CR an loosing a lott of bottom end. These heads would be on the way out at 7500.
However, bottom end torque can be enhanced with the right selection of gear ratio's. However you would loose top speed to gain low down. Overall it will be faster accelerating with higher gears.
My engine is planned for a 8000 rpm limit. Camshaft says it will rev to 7200 in a normal 350 so I would be able to get there I guess. I haven't had the chance to test.
I'm rambling but interested
I've turned a couple of SBC's I've built to 7000, but have no personal experience with an engine that lives in this RPM range.
I'd be interested seeing a cast cap stock block turn 8K...but only from a suitable distance and someone elses' funding
I agree usage is part of it, i.e. 8K on a circle track vs. 8K for 10 seconds...but I think in either case you'd be hard-pressed to keep that forged or billet crank in the block at those speeds.
It'd be fun to build one up and see
Piston speed is not the problem - Valve train is.
Pops
302 with a solid lifter cam will spin that high repeatedly and hold together.
For 8 G you can do quite a bit if you don't buy into "if its shiny it must be fast" stuff.
And actually, much higher than 8000 rpm. Try 9500.
The bottom end was a steel crank small journal with 2 bolt mains, with .004 inch clearance which all say is too much. It is for a 5000 - 6000 street engine, but at this speed, anything less wiped the bearings regularly. The crank floated on 85 psi oil pressure.
This was a road race engine and lasted for a lot longer than 10 seconds at a time. Once the bottom end was working, it went several weekends (a few hundred miles) before a valve dropped. Like gkull said, the valvetrain is the critical problem.
A header had cracked, it sucked cold air, and the valve went the last weekend before we knew something was wrong.
The main issue with 9500 is trying to convince a forever Chevy driver that 9500 is acceptable. I was always leery above 8000. Had it been a Mazda, I would have had no qualms with 12,000 or so, but that SBC at 9500 was nerve-wracking. (Strange is driving a car that when the 12,000 RPM tach pegs, you shift.)
My builder will do one for you. I still have most of the parts. Need a good SJ block that is solid at .020 over.
Send money.
