Seems as though I'm posting something new every day...sorry...
Last night I saw a mushroom cloud of smoke go out from under my hood. Stunk like rubba. Yep, belt going to the AC.
Not a big deal, no damage done, however, how do I replace the belt, whats the best way to get ahold of one, and should I do the other belts for maintenence records purposes?!
on your 76? i just installed new belts in my 70. i first went to autozone and got some dayco brand belts. they sat deep in the pulleys. went to bennett auto and got some goodyear gator brand. they felt heavier and sat up in the pully the way they should. i had to buy several sizes, and return the unused belts to find the correct length.
Sounds like the compressor clutch bearing. Better this than the compressor. You can replace the bearing or buy a rebuilt or new clutch assembly. You should consider having a professional install if your unsure how to install the belts.
