Any good lighting upgrade options?
Old Aug 21, 2007 | 02:44 PM
76REDVETTE's Avatar
76REDVETTE
Default Any good lighting upgrade options?
My buddy with a 79 has problems seeing at night with the low beams on. Is there any kind of upgrade available to help him out?
Thanks,
Jeff
Old Aug 21, 2007 | 03:07 PM
weimer20's Avatar
weimer20
You can put some xenon lights in it. I personally don't like the bluish light they put out and a picky law enforcement type may latch onto them as well. They work pretty good though.
Old Aug 21, 2007 | 03:13 PM
redman76's Avatar
redman76
St. Jude Donor '09
I installed a couple of 55W driving lights behind my grill for the same reason. My main issue was seeing when turning although my night vision has declined over the years. The lights have really helped light things up.
Old Aug 21, 2007 | 03:35 PM
76REDVETTE's Avatar
76REDVETTE
Isn't it a sealed casing? I have plug and play HID's on my other cars and they work great, they are 4300K temp so they emit no blue tint what so ever, its pure white. I thought HID's would not be able to plug and play into a C3?
Old Aug 21, 2007 | 03:41 PM
Bric's Avatar
Bric
Old Aug 21, 2007 | 03:54 PM
Overlord's Avatar
Overlord
From: Crush your enemies, see them driven before you, and hear the lamentations of the women TX
Actual HID lights with transformers and ballasts and such only pull like 35 watts. Of course you would have to get aftermarket housings/reflectors to plug the bulbs into. Of course the round corvette reflectors are available just about anywhere.
On my '99 trans am with the sealed beams with very off the wall proportions, where you just couldn't seem to find aftermarket reflectors, I bastardized some HIR lights into sealed beam Sylvania housings. Ramped up the melted plastic driving light housings with their 26.5watt bulbs into metal housings running 55 (or was it 65) watt zenon bulbs.
http://cgi.ebay.com/ebaymotors/TOSHI...QQcmdZViewItem
Here is another link to the complete 4 light Zenon replacement including harness running directly off the alternator;
http://www.vetteworksonline.com/cata...034fc6832c4122
They claim there is a lot of voltage drop over the stock harness and sell an upgraded harness for $200. I haven't taken a good look at the lighting or harness yet, but I am replacing bulbs with LEDs where feasible to ease the stress on what is actually a pretty primitive electrical system.
I do a lot of night driving on backroads; fast and dark. When I get to the lights on the list..... well, I like the option of seeing way down the road. Leaves on trees wilting..... small animals bursting into flame..... the paint on the bumper of the guy that cut me off slowly bubbling....
Old Aug 21, 2007 | 04:54 PM
SIXFOOTER's Avatar
SIXFOOTER
Go check out the article on MadElectric site, then start looking at the options. The existing wireing has issues, fix that first, then see if more improvement is needed
Old Aug 21, 2007 | 05:26 PM
gkull's Avatar
gkull
I'm just running 4 higher watt halogen.
Old Aug 21, 2007 | 05:49 PM
Durango_Boy's Avatar
Durango_Boy
For the time being this is my lighting upgrade. They are not sealed and you can use newer bulbs either halogen or blue.
I also wired up the halos you see as failing light accents to only be used at dusk before the headlights are switched on.
I also gave them dedicated power from my equivalent of the alt's BAT terminal switched by a relay that's triggered by the original headlight power wire.
It's all only temporary until I get my body work going and install the fixed headlights.
Old Aug 21, 2007 | 06:34 PM
weimer20's Avatar
weimer20
Now THATS pretty cool!
Old Aug 22, 2007 | 03:33 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Incandescent bulbs don't age well. Replace with some version of a modern halogen bulb (cheapo sealed-beams, aftermarket H4/H1 units, etc.). If pure originality isn't a concern, install relays.
Old Aug 22, 2007 | 07:11 AM
Paul L's Avatar
Paul L
Halogen is a low-cost option.
Or he can add auxiliary lighting behind the grille as well. These are Hella 1500 Optilux. They serve as daytime running lights (DRLs) during the day.
Old Aug 22, 2007 | 10:39 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Nice one, DB.
Old Aug 22, 2007 | 10:43 AM
bozzman3's Avatar
bozzman3
Try Daniel Stern lighting.He has excellent glass, european code headlights that are awesome.Lots of tech info on his site also.
Old Aug 23, 2007 | 05:49 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Cibies are good, but I've always been a Hella partisan. Either way, E-code lights rock. I still need to find one 5.75" H1 to finish my set...
Old Aug 23, 2007 | 06:46 AM
bb69's Avatar
bb69
I will second the suggestion to read through the MAD site. I simply rewired my headlights as they suggest and it made a world of difference. Check to see what kind voltage you get at the headlights with the engine running. If it's below 13.5V, improving your wiring will probably do what you need.
Ken
Old Aug 23, 2007 | 08:03 AM
Durango_Boy
Even if the stock lights are just replaced with newer sealed halogens then powering them from a 14+V relay will improve things significantly.
To Any good lighting upgrade options?
Old Aug 23, 2007 | 09:35 AM
Overlord's Avatar
Overlord
Sure do like the pattern on those new Cibies but $109 a pop is cruel. I may rewire and put in the high beams and reevaluate 'em.
Old Aug 23, 2007 | 10:11 AM
Overlord's Avatar
Overlord
Ken
I'm not putting a meter on the headlights, I already know they're anemic.
I can go to really low beams just rolling the window up.
So for upgrading and rewiring, who makes the best most accurate wiring diagrams?
Old Aug 23, 2007 | 10:18 AM
SIXFOOTER's Avatar
SIXFOOTER
This works well
