steering - c clip position??
Nothing really gets too close to it so I don't think it's orientation really matters...
...unless I'm thinking of a different C-clip.
http://jimshea.corvettefaq.com/wp-co...owup03FE04.doc
Here are the instructions:
"Reassembly - Horn Contact, Shaft Lock, and C-clip
Place the upper bearing preload spring #5, the horn contact carrier #4, and the lock plate #3 onto the upper end of the shaft. Note, the steering shaft yoke #44 has two flats on opposite sides of the open end. The flats are not equal in length. Assemble the horn contact carrier so that its flat matches the long flat on the shaft yoke assy. Also, the hub on the shaft lock plate is raised on one side. The raised section should be pointing toward you as the shaft lock plate is assembled on the shaft yoke.
Reinstall the locking rod #40 and the “star” screw/set screw. Telescope the upper shaft #41 inward to its shortest length and tighten the “star” screw with a phillips screwdriver (or the set screw with an allen wrench) to lock the shaft in place. Now compress the shaft lock with the special bridge tool or by hand and install the c-clip #2.
A Note of Caution: The c-clip is a critical safety part. If it is omitted or not engaged properly, the entire steering wheel and the upper steering shaft will be able to be pulled right out of the steering column at any time.
Reassembly C-clip Retainer, Bumper, and Spacers
Now, remove the “star” screw/set screw so that you can install the c-clip plastic retainer #1, the bumper, and spacers."
I make no mention as to the orientation of the C-clip.
I just found a statement in one of my old Steering Gear repair manuals.
"Locate the C-ring to lock shaft with the wider leg of the C-ring on the keyway side of the upper shaft. Install the C-ring retainer with the singel tab opposite the small lobe on the carrier. Snap the retainer over the C-ring and install the bumper."
Jim
Jim
I was thinking of a different C-clip all together. Sorry guys.
