Anti-theft Relay
Old Aug 22, 2007 | 11:20 AM
76 VETTE's Avatar
76 VETTE
Default Anti-theft Relay
Does any one know where to get one for my 76. Searched catalouges and can't find one. tHANX
Old Aug 22, 2007 | 12:12 PM
dobroman2001's Avatar
dobroman2001
'76, I too can not find the relay in any books. Check your PM... I just sent one with some questions for you.
Old Aug 22, 2007 | 01:41 PM
Bric's Avatar
Bric
Old Aug 22, 2007 | 03:06 PM
76 VETTE's Avatar
76 VETTE
There Must Be Some Out There Somewhere.
Old Aug 22, 2007 | 03:13 PM
SIXFOOTER's Avatar
SIXFOOTER
Check these guys out. The one in the car might be an oddball footprint or something, but they might have one that will work. It will need to be 12v operated and some quantity of NO and NC contacts. If you have a hard time with it send me a pic of the schematic and I'll help
helps if I include the link
http://www.digikey.com/scripts/DkSea...keywords=relay
Old Aug 22, 2007 | 03:34 PM
...Roger...'s Avatar
...Roger...
Dont think so.But I think you can make one out of a standard horn relay.I have been meaning to try.It a "hold in" relay in other words once its in it wont release until the 12 volts is taken away-the trick is on the ground side if I remember right.
Six-remember I made one on my embarrassing headlight relay.:o
Old Aug 22, 2007 | 03:53 PM
...Roger...
Six-There was something tricky about the ground.I think it had something to do with the case of the relay.See the term. thats not numbered on the horn relay.The alarm works off the ground side as you can see and cycles through a flasher."I" figured it out once so its got to be easy.!!!!!!!!!!!!!
Old Aug 22, 2007 | 04:10 PM
76 VETTE's Avatar
76 VETTE
Good schem. Looks about whats in my76.Thanx six and dwnchs. Might try a standard horn relay.dale
Old Aug 22, 2007 | 04:30 PM
...Roger...
Yes a standard 3 conn. horn relay like out of a 78 will work but the connections at the relay are different than a horn.If Six doesnt detail it for you I will later but I will have to go out and experiment.I can tell you one thing the 12 volts in "has" to be on the tiny coil wire inside relay.
Old Aug 22, 2007 | 07:13 PM
...Roger...
This how it has to be wired.You might have to change your wires in the connector.If these colors dont match what you have let me know.
Old Aug 22, 2007 | 07:41 PM
76 VETTE's Avatar
76 VETTE
That looks easy enough. I will try it. Can't believe no one makes them. Thanx
Old Aug 22, 2007 | 07:53 PM
...Roger...
Let me know if thats a direct plug in.The red wire or hot when attached to the horn wiring is the ground from the horn button.Maybe its all in the wiring.
Old Aug 22, 2007 | 10:45 PM
SIXFOOTER's Avatar
SIXFOOTER
I made some notes and unscrewed the relay a bit. Hope this makes sense
Old Aug 22, 2007 | 11:14 PM
76 VETTE's Avatar
76 VETTE
Wow thanx six. That really sums it up easilly. I always wondered how it worked.Would that be the same for a 76?Looks like it would be.
Old Aug 22, 2007 | 11:46 PM
SIXFOOTER's Avatar
SIXFOOTER
Dunno, can't imagine it being much different. TTop switches maybe? Other than that I bet its close. Be happy to mark one up if you have the schematic
Old Aug 23, 2007 | 07:53 AM
babylonvette's Avatar
babylonvette
Default alarm relay
it is listed in the standards parts book i found 1 for my 72 in there it is a relay that has many uses i am sure they all use the same relay go to an independent parts house and it should be available
To Anti-theft Relay
