Make sure your power steering control valve has been balanced. I had this same problem on my 1980, balanced the control valve and the car is so nice to drive.
Would this cause a 'groaning' sound when turning at slow speeds when cold. Fluids are good..
The third alignment spec - caster - has a great effect on a Corvette's steering. Many alignment shops will get camber and toe-on right and let caster fall where it may - usually 1 or 1 1/2 degrees (ot less!). This will make your car feel "darty". To get stable tracking and give a little heavier feel to the steering, caster should be 3 to 6 degrees. Sometimes this is difficult to achieve in a 25+ year old chassis which has "settled" and this is the reason that van steel and vette brakes offer upper A arms with an offset ball joint location. These parts help compensate for wear and achieve the stability you're looking for.
yes, go for max caster 6+ if possible
also, as mentioned by backdoorman use the manual tie-rod hole(i do)
This has been rehashed so many times over throug the years, i'ts funny allready.....
the facts are, IF everyone is mechanically home and happy as a clam, with NORMAL tires, the car does fine.....with wider tires the freeway wandering is subjective depending on specific tire, and the roads.....
meaning it's YOUR car, what can YOU TOLERATE???
When I first started driving I was surprised to find it was 'normal' at the time, for all the cars to 'wander' over the roads....no matter the speeds....constant nudging the wheel to the right/left was considered a normal part of driving, and it got worse on higher speeds....and worn roads appearing over time, then as years went by, the interstate freeways made from asphault getting rutted out, the situation got even more sensitive.....now we get wider tires....
and this olde tyme steering added on to a chassis born in the late 50's....is plainly not up to the job.....
CASE CLOSED.....IF the owner is happy with it, fine.....
others notice that problem....
I went to a rack as driving here in Florida is quite a bit differant than Wash DC....much more freeway driving....
and the steering/handling improved night to day....
wheel steady from 0 to 150, on all sorts of problem roads.....
I seem to have the same problem with my 78, after 70 mph I have to hold the wheel rock steady. It feels as if there is no play at all in the steering and the cars front end feels as if it's floating.
I am going to have an alignment check done to see if the caster is off as Rotonda has suggested.
All my pwr steering parts are new from VB+P but my pwr steering pump has been changed with a re-built from a discount parts store. I have no leaks, and the control valve seems to have been adjusted correctly.I cannot steer with one finger with the car sitting still, is there a part I should have swapped out from the original pump to the newer ones? Yellovette, did you change your pump also?
Reason: more info
From: Crush your enemies, see them driven before you, and hear the lamentations of the women TX
Originally Posted by yellovette
As someone said, it's like driving a go-kart. Fun, in a way, but takes too much concentration over a long trip.
yellovette
Actually you'll get used to it and no longer really notice it, at least not consciously. You'll lose that twitchy hand too.
Unless the camber is a magic bullet......
You'll always have to pay a little more attention to keep your AC compressor from getting behind the wheel of that parked car.
Each bump and pot hole will be an unwelcome adventure.
It may never be that long distance highway cruiser you envision.
That being said, my steering is still feral. But the car and I have come to terms. I'll certainly give the camber settings a try when I get it aligned. Not going to do that until I have some suspension equipment swapped/upgraded first tho.
Please let us know how it goes after they adjust the toe in and caster.
Mine was almost undrivable until I changed over to manual steering. Now it's great at high speed but a little tough in parallel parking. If yours works out after the alignment I may be tempted to hook up my ps again.
Not from an unbalanced setup - That's the sound of the pump "working." Usually, the groaning noise shows up when you turn the wheels completely either direction which is very hard on the PS mechanism. If you hear the groaning noise when you have the wheels cranked all the way, back off just a fraction and save some wear and tear.
Originally Posted by happiedazs
I have the exact same problem ---- i call it nervous steering. Not a real problem if your're traveling 60 mph or less ---- but at 70 or 80 mph it can make you a nervous wreck in a very short period of time as you are constantly turing the wheel back and forth to keep the car in the lane and little adjustments to the steering wheel seem to ofter go too far and then i have to recompensate. I have given up on this issue and believe I have just gotten used to my BMW and variable ratio steering ---- but if you find a soluton, please let all of us know because many seem to have the same issue
Don't give up! If your front end parts are not worn or broken, the road wander and finicky steering is totally associated with a proper alignment. You just need to find the right person who can set it up properly. A good place to start might be contacting the local Vette club and see if they know of anyone.
You'll never be able to steer with one finger with the car sitting still. The Vettes don't have the kind of steering associated with Toyotas and minivans. It's more of a "power assisted" steering...
