VB&P Lower A Arms
Old Aug 23, 2007 | 07:24 AM
langg's Avatar
langg
Default VB&P Lower A Arms
Hi.
I am finally installing a VB&P mono-spring kit I bought in December. A arms went on OK but my new Bilstein shocks won't fit. The bolt spacing is off by at least half a hole. It's not the shocks, they fit the stock a arms.
Anyone else have this problem? What did you do? I am thinking - elongate the holes in the shocks.
Old Aug 23, 2007 | 07:37 AM
SIXFOOTER's Avatar
SIXFOOTER
you sure you have them on the correct sides?
Old Aug 23, 2007 | 07:43 AM
langg's Avatar
langg
How would that affect the bolt spacing at the bottom? The shock fits as far as the interface with the top rod and the bottom seat. I just can't get both bolts in the bottom.
Old Aug 23, 2007 | 08:45 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
On their front monospring kit, the shock t-bar should have been modified. You'll have to send them back or do it yourself. Call VBP and talk to Gary.
Old Aug 23, 2007 | 09:05 AM
SIXFOOTER's Avatar
SIXFOOTER
I put a VBP setup on a members car a couple months ago, all 4 control arms and Bilsteins, and didn't have to mod anything.
Old Aug 23, 2007 | 09:09 AM
Van Steel's Avatar
Van Steel
B/C they are supposed to do it before it leaves their place and is probably what happened.
Old Aug 23, 2007 | 10:22 AM
SIXFOOTER's Avatar
SIXFOOTER
Ahh
Old Aug 24, 2007 | 02:06 AM
gkz's Avatar
gkz
Yeah, I had this problem. A few minutes with a round file and you're good to go....
Old Aug 24, 2007 | 06:51 AM
Gordonm's Avatar
Gordonm
I had to mod mine a little also. I bought my kit from a forum member and used my previously bought Bilstiens. Slight mod with a grinder is all it takes.
To VB&P Lower A Arms
