Bolted on some new aluminum trick flow heads to a stock 350 block. Getting a bit of coolant leek from the drivers side. Doesnt look like im getting any in the cylinder as the exhaust seems pretty clean. Should I just try retorquing or pull the head and try a non copper gasket?
Leeks are good for you!!
What type of head gaskets are you using??? re-torquing one bolt at a time might help
Go with a traditional style composite head gasket and life will be good.
Unless you are running a blower I would not use the copper head gaskets. I have been down this road with my 65 blown 427 and the only way I got it to seal was to dissassemble, clean and reassemble.
Blue RTV is not the best even though it says it's rated for coolant and oil. If all the bolts are torqued properly and a better RTV is used there should be no issues. If the silicone is "washed away", retorque is not going to help. Does it leak only at certain times or temps, such as warm ups?
I prefer gaskets with an embossed bead instead of just a flat sheet. These conform to surfaces and adapt to different temperature changes and the changing expansion rates of multi-metal (cast iron, aluminum,etc) engines. For the money you spent on those you could have gotten MLS stainless steel viton coated gaskets for for your application. Though the hiperf composites would have been fine. Cooper are better for re-usability, such as teardowns between rounds or races, but not typically ideal for street. Though depending on application we've been able to reuse the MLS's over again. But don't let them know I told you, that's like taken food off my kid's table when you don't have to buy more.
Do not spray or coat the composites or coated gaskets as they have been engineered to seal yet let the parts expand and "slide around" at different rates.
From: Graceland in a Not Correctly Restored Stingray
Copper is only truly worth the trouble for hardcore engines. I never ran them without O-ringing, but if you insist - Indian Head Shellac...
Should you change head gaskets, make sure and do the math on piston to head clearance. You're looking for about 0.040 - 0.050", ideally.
Long ago I ran copper head gaskets on a blower motor in a boat. The heads were o-ringed, so as long as water didn't get into the cylinders, I didn't care if they leaked.
Copper is only for race motors that get frequent tear downs. I use Flatout silicone/rubber coated copper head gaskets because I needed .021 thickness to get my quench down to .041. But I also have a aftermarket engine block where all the head studs go into blind holes. That is the where the block casting is made so no water or oil is open to the bolt or stud.
I use fully studded motors to keep the heads correct. But one overheat and copper head gaskets can start to leak. You are better off using FelPro for Aluminum heads
Without perfect surfaces the copper can not seal. That where O-ring blocks help.
