High zinc oils
Old Aug 23, 2007 | 09:31 PM
JustinD's Avatar
JustinD
Default High zinc oils
I want to run a high zinc oil. What would be my options?
Old Aug 23, 2007 | 09:40 PM
tlrs819's Avatar
tlrs819
I use rotella T 15 w 40 but heard they are dropping a lot of zinc out of it now. I'm considering mobil 1 v-twin oil now, It's the highest zinc content I can find. Could also just dump some comp cams break in additive to any oil you please.
Old Aug 23, 2007 | 09:45 PM
Roughrider's Avatar
Roughrider
You can also buy GM's cam pre-lube and add it. Most GM dealerships will have it.
Old Aug 23, 2007 | 09:48 PM
JustinD's Avatar
JustinD
So I mobile v-twin or a bottle of additive.
Old Aug 24, 2007 | 01:18 PM
Kalway's Avatar
Kalway
I've been using Valvoline VRI 10w30 lately. My engine was rebuilt about 2 years ago with a bit tighter tolerances so I need the oil to be a bit thinner. VRI has a good amount of zinc in it.
Royal purple is another option, but it's like $9 a quart!
Old Aug 24, 2007 | 01:25 PM
Little Mouse's Avatar
Little Mouse
Whats considered a high amount of Zinc and how much is to low??
Old Aug 24, 2007 | 01:57 PM
Kalway's Avatar
Kalway
Normal conventional motor oils have somewhere around .08% zinc. Valvoline VR1 has .130% (% of weight)
Many conventional oils out now don't even list any zinc.
Old Aug 24, 2007 | 02:03 PM
Little Mouse
Is this VR1 another form of Valvolines racing oil??
Old Aug 24, 2007 | 02:06 PM
Kalway's Avatar
Kalway
Sure is, it's like around $50 - $60 for a box of it. Basically half the price of RP. I've been running it for the past 4 or 5 months and it seems to be holding up pretty well. Having my rear main seal replaced today so I'll find out how well it's doing its job later.
Old Aug 24, 2007 | 03:41 PM
Donald #31176's Avatar
Donald #31176
API SM oil is phosphorus (anti wear component of ZDDP) limited to 800 parts/ million and lower viscosity "Energy Saving " SM is even less. The richest ZDDP additive package is found in API rated CI-4 . CI-4 depending on the vendor has between 1000 to 1500 parts/ million ZDDP. API CJ-4 is the newer diesel rated oil has a little less ZDDP ( up to 1200 parts/million ZDDP) Since there are still many high sulfur diesel fuel engines in use the richer ZDDP package is NOT going away anytime soon and should be available for at least 5 years. Any brand CI-4 and the appropriate viscosity should be the prime selection of oil for flat tappet engines.
Old Aug 24, 2007 | 04:02 PM
Little Mouse
Originally Posted by Donald #31176
API SM oil is phosphorus (anti wear component of ZDDP) limited to 800 parts/ million and lower viscosity "Energy Saving " SM is even less. The richest ZDDP additive package is found in API rated CI-4 . CI-4 depending on the vendor has between 1000 to 1500 parts/ million ZDDP. API CJ-4 is the newer diesel rated oil has a little less ZDDP ( up to 1200 parts/million ZDDP) Since there are still many high sulfur diesel engines in use the richer ZDDP package is NOT going away anytime soon and should be available for at least 5 years. Any brand CI-4 and the appropriate viscosity should be the prime selection of oil for flat tappet engines.
I have a bunch of older cases of mobil delvac 1300 diesel oil,
but JustinD has some Castrol GTX oil and I don't believe he
knows if it has much zinc in it if any. Sounds like any of the newer
diesel oil would still be good or the VR1 valvoline.
Old Aug 24, 2007 | 04:31 PM
Kalway's Avatar
Kalway
Diesel oil is probably fine if your engine has a lot of miles or has forged pistons, but if your engine is relatively fresh 15w40 is pretty thick stuff and I don't think it'd properly lubricate the tight areas. Hence why I'm running 10w30. I prefer 5w30 or 10w30 over any of that heavy oil as my engine RARELY gets over 180 degrees and I need that cold lubrication. I can see the need for it if your engine is revving hard for long periods of time, though...
So I shall be sticking with the VR1 since it has plenty of zinc and actually comes in a light multi-viscosity.
Old Aug 24, 2007 | 04:33 PM
JustinD's Avatar
JustinD
It seems that castrol gtx has .12 zinc. Whatever that means. I also read that valvoline race is .20.
http://www.fjfan.com/technical/motoroil-faq.htm
Old Aug 24, 2007 | 04:42 PM
Kalway's Avatar
Kalway
I'm curious as to when that data was collected.
According to Castrol's datasheet, GTX has zero zinc.
Old Aug 24, 2007 | 04:52 PM
JustinD's Avatar
JustinD
Must be old or something.
Old Aug 24, 2007 | 05:30 PM
Donald #31176
What is the current API rating Of Castrol GTX? The above report is for API SG/CD rated oil. API SG/CD rating is at least 6 years old .
To High zinc oils
