Help....Vette for $2500.00
Old Nov 7, 2001 | 09:40 PM
Rods77's Avatar
Rods77
Default Help....Vette for $2500.00
My 77 got into a front end accident Sept 29, my friend has a neighbor with a 74 that he will sell for $2500.00. Will look at the car tomorrow but as far as I know the rear window is gone and the dash is tore apart, but the rest of the car is there. I want to use the front clip, headlight buckets, and brackets to rebuild my 77. Will the front clip of a 74 interchange with a early 77?
Old Nov 7, 2001 | 09:45 PM
rdrman's Avatar
rdrman
Default Re: Help....Vette for $2500.00 (Rods77)
The bumper is differant if that matters to you
Old Nov 7, 2001 | 09:46 PM
daily_driver's Avatar
daily_driver
hmm 2500 for a 74 with a ripped up dash and no rear window!!!
sounds like a steal for a project car ta me!!!
as long as the body is good that is...
wish i had 2500 dollars id buy it for a 2nd one!!
:jester
Old Nov 7, 2001 | 10:37 PM
Rods77's Avatar
Rods77
I should say, I don't want the 74 look (not that I don't like it, just trying to keep the 77 looking like a 77). Looking through the parts catalogs and some pictures and it appears the front fiberglass and bumper is different than the 77. Wonder if the headlight buckets are the same? Not sure if this is going to work... :confused:
Old Nov 7, 2001 | 10:51 PM
69vette66's Avatar
69vette66
if you buy the 74, I would be interested in the front grilles. left, right, and center. thanks
Old Nov 7, 2001 | 11:20 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
I'd buy the car in a heartbeat. Even if it's not worth a crap, the parts are.
Old Nov 8, 2001 | 09:25 AM
Alwyn678's Avatar
Alwyn678
Default Re: Help....Vette for $2500.00 (joeveto)
For that price..You should buy it!!! I am sure you will find that a lot of the parts are interchangeable
Old Nov 8, 2001 | 09:35 AM
1LE's Avatar
1LE
I think the only difference in the bumbers are the bumber pads. 73 and 74 did not have them. 75 on did.
Old Nov 8, 2001 | 09:44 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Rod, everything should go together OK, the only thing is the other person mentioned is the '74 bumper will NOT have those bumper pads on each side of the license plate. Also, a '73/'74 bumper is "straight" across at the top center of the "V". A '75-'79 bumper protrudes up an inch, then is about 10 inches long on this upper "indent".
Old Nov 8, 2001 | 10:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The '74 front bumper and related hardware is different (more or less straight across). That makes the upper surround panel also different. HOWEVER, the rest of the sheetmetal is essentially the same as your '77. The entire front clip will bond on to your '77.
To Help....Vette for $2500.00
