75 t-top & weatherstrip alignment
Old Aug 29, 2007 | 04:53 PM
land75's Avatar
land75
4th Gear
Default 75 t-top & weatherstrip alignment
What documentation should I get that shows how to align the t-tops and weatherstripping around the door window so that it goes up properly and seals?
The weatherstripping was recently replaced by someone incompetent and the window doesn't fit into the seal at the top.
Does the book Corvette Water Leaks and Wind Noise Solutions
by Michael J. Davis cover this?
Thanks,
Tim
Old Aug 29, 2007 | 10:39 PM
Artsvette73's Avatar
Artsvette73
You may have to do some window adjustments. Raise the stops on the vertical glass channel.
