Too much oil pressure bad?
You can use a stock spring with some shims behind it to kick it up. Maybe .100" or so.
That oil pressure *curve* sure looks like a HV pump's output. Must be a heck of a tight bottom end! And that's good!
JIM
Have you confirmed these readings with another gauge? just curious, maybe your gauge calibration is off eventhough it goes up and down as RPM does.
Not to side track, but do you know the size of the oil fitting on the block? is it 1/4? 1/2?
And then what is the oil gauge fitting size? 1/8?
Mine has an adapter that screws into the block right above the oil filter and then the gauge fitting screws into the adapter.
I run a Melling HV-77 High Volume Oil Pump that I installed in it 30 years ago. Bottom end has never been touched and block never been bored and my oil pressure is excellent....
I run Delo 400 Diesel 15w-40 in it and I have 80lbs oil pressure then 70 after it warms up. It loves it.
I also have a external oil cooler plumbed into the system which drops the oil temp considerably,its great! I like the extra pressure and volume in conjunction with the oil cooler lines that run to and from the front of the radiator.
68 NJConv 454, I don't remember the size at all. It's been almost a year since I worked on it. Sorry.
the thin triangle air cleaner to show it all off that trips my trigger.
without the angled vacuum canisters the barry grant stuff just does
not look as good to me.
Next oil change, pop some 5w30 in it. This should provide a slight decrease in oil pressure with no ill effects.
I would have suggested a high volume pump versus the high pressure pump. I believe it would have worked much better in your situation. The increased flow would provide the proper lubrication and should have raised the pressure up to proper levels. If you flow enough oil that it cannot squeeze out of the clearances, this will create pressure. Right now you are just creating pressure with minimal flow increase.
Mike
In the days when I first bought my car (1967) everyone ripped off the tri power setups and replaced them with 4bbls, because as you and I know they were a PIA with leaks and no reliable operation of those weak vacuum secondaries, which really are a joke. I have converted mine to progressive linkage so that the 2 outers actually do work....I was literally tripping over these Tripower setups at parts houses and swap meets.....no more now big $$$$$$...I agree the the BG tri power setup looks way to modern for a 40 yr old BB vette....
having any trouble with the secondaries not opening, but they
were said to work better for performance with progressive linkage
but I never did try it. I paid $85.00 dollars for the complete setup
it was not on a car when I bought it, so I spent about $20.00
for three carb rebuild kits. 18 months later when I got rid of the
73 I put the engine all back to stock with the stock parts I had kept
even the exhaust manifolds, I then sold the trypower for $125.00
this was late in 1974 maybe early 75.
Mike
The bold part of that statement is exactly correct. But the second part seems misleading somewhat.
Pressure is pressure.....if you have 60psi with a stock pump and 60 psi with a HV pump...you have the same amount of flow through the bearings. Nothing in engine has changed to allow more oil flow. If you increase pressure....regardless of the pump design..flow will increase. Again, pressure is pressure.
Oil pumps are very simple devices. They are designed to supply a certain volume of oil at a certain pressure. The stock pump is capable of exceeding the requirements of a normal clearanced engine. Throw a HP spring in it and the fact is proven. It just keeps building more pressure as rpm climbs. They are RPM driven....at *X* rpm...say idle...they will move *Y* amount of oil. If the clearances are *normal* then you will end up with the *normal* oil pressure. If they are loose it will be lower..tighter..it will be higher. Real simple design.
As RPM climbs...the pressure builds because it's trying to move more oil than the engine is *hemmoraging* inside. Of course as RPM climbs...more oil is thrown out of everything....but the stock pump can still *outrun* the leak...and proves it again since oil pressure is rising.
If you want insurance as RPM climbs you use a bigger spring in stock pump and build more pressure.
The HV pumps...are approx 25% or so larger. They just are able to pump more oil for a given RPM. And since that's the case...they outrun the leaks at a lower rpm and hence hold more oil pressure at low speeds. Nothing else has changed in the engine to require more oil flow..so you just get more pressure. As RPM climbs...they just keep outrunning the leaks and are able to build more pressure than the stock pump at the same RPM throughout the range.
If you put a 70 psi spring in a stock pump..you will only get a max of 70 psi at *X* RPM. If you put a 70 psi spring in a HV pump..you will still only get 70 psi at the max....but at lower rpms. Where the stock pump may be supplying 40 psi of pressure at a certain RPM..the HV may have 60 psi at same RPM.
I run a lot of solid roller stuff with EDM oiling to axles and us Lunatic Hardcore Fringe folks have a tough time keeping lifters alive. I like the added oil pressure/flow at low rpms to keep the lifters well oiled.
JIM
I know the spring is only $3 or so but some times you might not have one handy.
-Mark.
