Best rebuilt Q-Jet?
Old Aug 31, 2007 | 03:48 PM
column5's Avatar
column5
Default Best rebuilt Q-Jet?
Whose rebuilt Quadrajet is the best? I see that Holley, Summit, JET, and even NAPA have them. I've read on this forum to stay away from the Holley-rebuilt ones.
Old Aug 31, 2007 | 04:18 PM
celeryman22's Avatar
celeryman22
From what I have read most of the rebuilt Q-jets are not built correctly. If you want it done correct ask Lars if he is able to do it for ya. Or read his papers, ask some questions and do it yourself.
Mike
Old Aug 31, 2007 | 04:22 PM
column5's Avatar
column5
Mike
Rgr that. I've cleaned and rebuilt the thing, and I re-bushed the primary throttle shaft last night but I still have a rough idle and a bit of stumble at cruise throttle. Starting to think it isn't the carb...frustrated now...
Old Aug 31, 2007 | 05:09 PM
celeryman22
What is the float set at? From what I have read if the float is not set perfect you can run into a wide range of problems. I believe anything newer than 1975 should have the float set at 0.420", Im sure Lars will chime to confirm.
I am currently working on my Q-jet also.
Old Aug 31, 2007 | 05:53 PM
SIXFOOTER's Avatar
SIXFOOTER
Best is by Lars, he is the carb guy in here
Old Aug 31, 2007 | 07:32 PM
nastee383's Avatar
nastee383
JET does good work.
Old Aug 31, 2007 | 07:38 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Mine will be tuned on the advice of Lars.
Old Aug 31, 2007 | 08:42 PM
Tim H's Avatar
Tim H
Mine was rebuilt by Holley and ran perfect on a stock engine.
Any upgrades and you will have to upgrade the Q-jet also.
Old Aug 31, 2007 | 11:08 PM
column5's Avatar
column5
Thanks for the info guys. After doing some research this evening, and playing with the motor a bit, I think my idle and cruise roughness may not be related to the carb at all. I think I may have lashed my valves a little too tight when I was rebuilding the top end a couple of weeks ago. Going to work on that in the morning.
To Best rebuilt Q-Jet?
