header gasket blow outs
Old Sep 2, 2007 | 01:41 PM
turbovette80's Avatar
turbovette80
Default header gasket blow outs
Is it possible the the draw thru turbocharger is producing too much back pressure which is repeatedly blowing my header gaskets,including aluminum "seal for good",and two sets of regular Mr Gaskets.I keep the bolts tight weekly.
help please.
Old Sep 2, 2007 | 05:53 PM
Durango_Boy's Avatar
Durango_Boy
First I would check to see if the flanges on the headers are perfectly square, and then check the flange surfaces on the heads.
If they are perfectly square it may be a pressure problem.
Old Sep 2, 2007 | 06:19 PM
mrvette's Avatar
mrvette
Two things....ONE, really old Pontiac engines they quit making in '78, used a very similar exhaust pattern...two on end, two in middle , adjacent....and they NEVER to my extensive knowledge used any gasket from the factory....iron to iron....never heard any leaks either....
TWO, allthough my SBC knowledge is more limited...I wonder if gaskets are necessary with iron factory style manifolds....I suspect NOT....
so....I wonder if the turbos are better off being fed from a cheep iron 2.25" rams horn mani into the turbos and beg the entire question, as headers feeding into a restriction like a turbo or any muffler/long pipe are rendered useless.....
no gains from indivudual tubes/collectors is what I"m saying....
so, it seems that other than COPPER gaskets, you maybe have to redesign the turbo input plumbing....
Old Sep 2, 2007 | 07:13 PM
gkull's Avatar
gkull
FelPro steel blue and header exhaust studs. Look at my home page on this forum.
To header gasket blow outs
