AC High Pressure Port
Old Sep 3, 2007 | 03:28 PM
RMS73's Avatar
RMS73
Default AC High Pressure Port
Is it better to have the high pressure port before or after the condenser? My 1973 does not have a high pressure port connection and I am trying to decide to put one on the high pressure hose between the condenser and the VIR or have one welded in the block at the back of the compressor.
Roger
Old Sep 3, 2007 | 03:57 PM
SIXFOOTER's Avatar
SIXFOOTER
The high pressure port should be right after the compressor. You want to measure real high pressure from the pump instead of something less after some kind of restriction.
Old Sep 3, 2007 | 04:41 PM
theoUK's Avatar
theoUK
73's a bit different to the CCOT system on the later c3 vettes, my 80's HP port is in the high pressure LIQUID line between the condensor and the evaporator.
As I see it, you would benefit most from being able to measure the hi pressure liquid pressure AFTER the condensor, because it's this pressure that you use to work out the amount of sub-cooling you're getting in the liquid coming out of the condensor, from which you get a handle on the condensor efficiency.. Not really sure how much meaning you get from measuring the high pressure VAPOUR pressure (ie between comp and cond).
As I say, the TXV system is obviously fuctionally differant to the CCOT, but you'd get the condensor sub-cooling measurement in the same way for both... That's all I know, sorry it ain't a definitive answer!
Need someone who (unlike me!) has done a bit more than just working on one type of system - Hopefully noonie will chime in and spread a bit of knowledge...
Old Sep 3, 2007 | 05:09 PM
noonie's Avatar
noonie
Both you guys are right
It really doesn't matter.
Usually it is on the high side at the compressor or near the condenser inlet. Mostly a matter of service accessability.
Bottom line being, whether it's a liquid or a gas it's still going to show the same amount of pressure in a closed system. That doesn't change until after the oriface.
It's probably safer before the condenser, in the rare case that an inexperienced person tries to connect or disconnect with the system running and spews liquid refrigerant all over themselves. Not good.
As far as adding a high service port for a high side cutoff switch, I would prefer it after the condenser.
Old Sep 4, 2007 | 05:24 AM
theoUK's Avatar
theoUK
Yeah, of course. There's actually very little flow, so the pressure drop across the condensor's going to be pretty small. It's almost static pressure. Never thought of that
Old Sep 4, 2007 | 10:51 AM
HABIT's Avatar
HABIT
If it aint broke Dont fix it . . .
To AC High Pressure Port
