Spicer U-Joints
Old Sep 4, 2007 | 07:06 AM
c3corvettes's Avatar
c3corvettes
Default Spicer U-Joints
Where can I buy Spicer Solid (no grease fittings) u-joints for my '80 shark. I need them for the driveshaft and both half shafts. Please recommend any websites with a solid reputation. Are these better than u-joints with the grease fittings?
Thanks and keep passing the wave
Old Sep 4, 2007 | 08:02 AM
Highhat's Avatar
Highhat
Call
FORT WAYNE CLUTCH & DRIVELINE
1-800-257-8243
Old Sep 4, 2007 | 08:07 AM
72 LT1's Avatar
72 LT1
I got mine from Van Steel, a supporting vender.
Old Sep 4, 2007 | 08:09 AM
mrvette's Avatar
mrvette
Ft. Wayne is supposed to be cool about it, BUT, apparently there has been a recent change by Spicer, and so the grease cup seals, that rubber on the ends of the bearing caps....SPLITS and cracks....
inferior quality....so be aware....
IMO, I been using Brute Force for a long time now...275/50/17 rubber but I don't drag race....been fine for me for some ten years + now...
Old Sep 4, 2007 | 04:58 PM
mapman's Avatar
mapman
I just purchased mine locally at a bearing supply store.
Old Sep 4, 2007 | 05:00 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I use Brute Force with no problems.
Old Sep 4, 2007 | 05:52 PM
1fastC3's Avatar
1fastC3
got mine from summit, they listed them as Strange Engineering but upon arrival they were in spicer boxes with a Strange Engineering sticker on it. good luck with whatever you decide.
-alex
Old Sep 4, 2007 | 08:00 PM
bt57's Avatar
bt57
these guys have any grade you would need
http://www.riversidegear.com/categor...nts/index.html
Old Sep 5, 2007 | 09:31 AM
Belgian1979vette's Avatar
Belgian1979vette
Can the 1350's used on the driveshaft as well ?
Old Sep 5, 2007 | 12:27 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Yes but you have to change the pinion on the diff and go to a Mark Williams slip yoke. You will also have to buy a new driveshaft b/c the 1350 pinion yoke is 1" longer than stock and your stock shaft won't fit.
Old Sep 5, 2007 | 02:32 PM
Belgian1979vette
What size would fit on the driveshaft ? And do the 1350's fit on the half shafts ?
Old Sep 5, 2007 | 04:00 PM
Van Steel's Avatar
Van Steel
I'm confused. I said that 1350's would work for a driveshaft but you need to mod or buy a new shaft. 1350's are in stock 1/2 shafts from 63-96 except 80-81 auto. Stock driveshafts from 71-79 use 1330 u-joints.
Old Sep 9, 2007 | 08:25 PM
Hadez's Avatar
Hadez
to my surprise today when I was swapping out my newly bought (August) 3" half shafts from Fort Wayne Clutch trying to figure out where a new 80+mph driveline vibration was coming from I found my Spicer's plastic seals had cracked right off after only 500 miles.
Old Sep 10, 2007 | 11:07 AM
Van Steel's Avatar
Van Steel
This change is not recent. They have been that way for about 2 yrs now. Neapco joints are another good alternative.
Old Sep 10, 2007 | 12:32 PM
GTR1999's Avatar
GTR1999
Chances are they were cracked during install. I haven't had one fail after install but have found new joints with crackes rings.
Old Sep 10, 2007 | 12:43 PM
Hadez's Avatar
Hadez
I checked them all for cracks as when they arrived in the box from Fort Wayne Clutch 1 of them had the cracked ring. So I honestly carefully inspected them all and did not find any other cracks. I would understand maybe me missing 1 cracked ring, but 2 I find very hard to believe. I might get them replaced with some of the other recommendations you guys have posted as this is getting old replacing stuff that was just recently installed.
Old Sep 10, 2007 | 12:49 PM
2armor's Avatar
2armor
Can someone explain the difference between the two exactly- for me and future readers?
I presume its for increase HP tolorance since they are solid? If so what HP level are we talking?
I just put 2 new Federal-mogul zerk type U-joints on my drive shaft.
I thought that was a good thing? I'm making around 350 HP max.
To Spicer U-Joints
Old Sep 10, 2007 | 01:18 PM
Van Steel's Avatar
Van Steel
2armor
Greaseable joints have a hollow channel that runs to each cap of the joints. By being hollow it's weaker. Solid joints are just that. Solid all the way through. Solid joints are stronger and handle more toque. It's tuff to put HP ratings on parts, especially u-joints. I would say greaseable joints are good to about 350hp. Anthing over that I would go w/solids. Plus with solid joints, you don't have to maintain them and they don't sling grease everywhere. For the extra couple bucks it's worth it in my opinion.
I think you'll be fine with the greaseable joints you put in your driveshaft. Most of the time the 1/2 shafts go before the driveshaft.
Old Sep 10, 2007 | 01:47 PM
vette blue's Avatar
vette blue
Just checked at NAPA and they told me they have Neapco performance U joints which are non greaseable. It says NAPA on the box but their tech rep insists they are made by Neapco. Would anybody know if these are the same as the Brute Force? Is Brute Force made by Neapco?
Old Sep 10, 2007 | 01:57 PM
2armor's Avatar
2armor
Originally Posted by Van Steel
2armor
THANKS! Thats kinda what I figured. I did think the grease zerk types would be rated higher though. I haven't bought the 1/2 shaft ones yet but will when I replace the rear spring. I'll keep this info in mind then.
