help with 82 crossfire injection
Old Sep 4, 2007 | 11:37 AM
pcreps's Avatar
pcreps
6th Gear
Default help with 82 crossfire injection
my 1982 corvette, where do i start, put a new motor in her, new exhaust, new fuel injectors, map sensor,,why is she flooding herself out, the top, injector is pouring to much gas and flooding her out...help me please . pcreps . the red vette is called CHRISTINE...
Old Sep 4, 2007 | 12:12 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
What other problems are you having??? It doesn't sound like you need a new engine.
Old Sep 4, 2007 | 01:43 PM
pcreps's Avatar
pcreps
6th Gear
Default my 82 crossfire injection
I just put a new motor 3 months ago, it just keep flooding itself out, the front new injector wont close and keeps dumping to much gas in, and it shuts off. pam
Old Sep 4, 2007 | 01:54 PM
Luster's Avatar
Luster
Fuel Pressure Regulator.
Old Sep 4, 2007 | 01:55 PM
1982CorvetteDude's Avatar
1982CorvetteDude
On my TPI, the injectors were dumping too much gas into the engine causing it to run rich, the biggest cause of this was I didn't have my exhaust sealed up correctly causing the oxygen sensor to "see" a false lean condition. Air was getting in through the doughnut seals and screwing my sensor readings up.
To compensate the injectors would pulse a little longer......because of this the engine ran like crap.
I installed new gaskets and made sure my exhaust was "air tight" and it fixed my problem.
You can get the same problems like this too if you have a vaccum leak around the intake as well.
Old Sep 4, 2007 | 01:57 PM
TERRY CLARK's Avatar
TERRY CLARK
Could be the Computer !
Old Sep 4, 2007 | 03:47 PM
bluesilver82's Avatar
bluesilver82
could be a bad injector if the front injector is the only one dumping to much fuel. However, that is good advice about the exhaust leaking air. My car runs rich and I can not figure out why. Maybe just maybe that is my problem too!.
Old Sep 4, 2007 | 03:51 PM
pcreps's Avatar
pcreps
6th Gear
Default 82 corvette
thanks for your help guys, it was a clogged EGR valve...thanks again:
Old Sep 4, 2007 | 04:06 PM
1982CorvetteDude
Good deal, Make sure you do a fresh oil change in case there is a lot of fuel mixed in with your oil. Check you plugs too and make sure they aren't fouled.
Old Sep 4, 2007 | 05:28 PM
pcreps's Avatar
pcreps
6th Gear
Default 82 corvette
yes, changing oil and new plugs are being done this evening...thanks
Old Sep 4, 2007 | 09:02 PM
Dirtbuster1's Avatar
Dirtbuster1
Try the crossfire injection vault website.
http://www.crossfire.homeip.net/
To help with 82 crossfire injection
