power stearing control valve
Old Sep 4, 2007 | 03:08 PM
xmen2121's Avatar
xmen2121
6th Gear
Default power stearing control valve
could someone help with this problem
i have a 78 vette with a 454 engine and with over sized valve covers
so i went from a brake booster to a hydraboost set up becouse my valve cover touched the brakebooster
the problem is i cannot balance my powerstearing control valve
i followed the directions that came with the control valve and nothing
when i think i have it the stearing wheel starts moving by it's self
from left to right
thank's in advance
ted
Old Sep 4, 2007 | 03:40 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Sounds like it's still not balanced. Try it again with small increments in adjustments.
Old Sep 4, 2007 | 03:58 PM
68 NJConv 454's Avatar
68 NJConv 454
Can you post links to what information your following? so we can help.
Old Sep 4, 2007 | 04:05 PM
xmen2121's Avatar
xmen2121
6th Gear
i'm using the haynes repair manual
Old Sep 4, 2007 | 05:28 PM
crazywelder's Avatar
crazywelder
Originally Posted by xmen2121
the stearing wheel starts moving by it's self from left to right.
The steering cylinder should be removed from the frame end, if your steering wheel is moving it sounds like the cylinder bracket is still bolted to the frame? If the steering is moving left to right, the adjustment nut needs to be turned counter-clockwise until the cylinder retracts.
Do you have the balance procedure from the GM manual? If not you can get it here:
http://jimshea.corvettefaq.com/?page_id=4
Old Sep 4, 2007 | 07:17 PM
xmen2121's Avatar
xmen2121
6th Gear
thank you for that link
Old Sep 4, 2007 | 10:39 PM
Jim Shea's Avatar
Jim Shea
Did you try to deaireate your power steering system after installing your hydroboost unit? You need to jack up the front tires and rotate your steering wheel a couple dozen times full lock to full lock - BEFORE starting your engine. The movement of the assist cylinder back and forth during this procedure will pump large air bubbles into the pump reservoir where they can escape to atmosphere. Refill with oil as the level goes down as the air comes out.
Once you start your engine, any large air bubbles travel into the pump and get whipped with the oil into a froth. Some people report that the oil in their reservoir suddenly overflows because foamy oil takes up quite a bit more space than plain oil. The air will eventually will work its way out of the system. It just might take a couple days.
I might guess that you probably have some air still left in your system. That can make the power assist and the steering to be quite erratic.
Jim
To power stearing control valve
