Red hot manifold!
Old Sep 5, 2007 | 12:32 AM
MI-CORVETTE's Avatar
MI-CORVETTE
Default Red hot manifold!
Just got back from a cruise tonight and the car seemed pretty warm inside so I thought I'd pop the hood. The exhaust manifold on the passenger side was pretty red. The vacuum actuated flap(heat riser valve?) has been disengaged as it had been sticking slightly shut and causing an exhaust leak previously. But that was several miles ago and this is the first time I've noticed this kind of heat considering the weather wasn't that hot today.
I'm wondering if there is a spacer that can replace this flap(valve) so I can get it out completely. Otherwise, I have access to a set of shory headers that I would assume my local exhaust shop can make fit.
Any thoughts?
Old Sep 5, 2007 | 02:15 AM
stingr69's Avatar
stingr69
Yes there is a spacer. It is used originaly on fuel injection cars. All the Corvette parts houses should have it.
-Mark.
Old Sep 5, 2007 | 06:14 PM
Duke94's Avatar
Duke94
http://www.zip-products.com/Zip/prod...41D298F8DFDAD0
Old Sep 5, 2007 | 06:20 PM
MI-CORVETTE
Thanks Mark/Duke for the replies. I'm going to look into that spacer, probably go to Corvette Central as they are pretty local for me.
Also, I was chatting with a guy today and he mentioned that it may be some unburned fuel burning in the manifold. Anybody ever heard of that? Last week I installed a new cap/rotor and tonight I'm putting in new plugs. Only other thing I can think of is to replace the plug wires.
Old Sep 5, 2007 | 08:01 PM
Duke94's Avatar
Duke94
When I first installed my new engine, I started it up and set timing at 8 degrees per spec. Within minutes, both headers were cherry red. Shut the engine off right away and let it cool (scared the he** out of me). Checked and double checked everything, asked the guys on the Forum and the concensous of opinion was that the timing was way to retarded for my set up. Got the vacuum gage out and set the timing for max vacuum and no more red headers. Rechecked it with a dial back light and it was about 15 degrees. I now set timing per Lars instructions (see his write ups elseware on this site), set max at 36 degrees and don't bother with initial timing. Works great.
Old Sep 5, 2007 | 09:50 PM
MI-CORVETTE
Default Timing might be it
Duke, I just installed plugs and took it for an easy ride. Upon returning home I immediately opened the hood and found that both manifolds are red hot right where all 4 ports come together. The plugs seemed pretty consistently the same color (light tan).
Timing will be the next thing I'll work on. Thanks again, I think you are on to something here.
Old Sep 5, 2007 | 11:06 PM
markdtn's Avatar
markdtn
If the flapper is bad anyway I would just modify it. On my TPI truck conversion that's what I did. I took off the flapper valve, removed the actuator, ground the rivets off the flap, removed the flap, removed the rod, used a small "freeze plug" on 1 side and drilled and tapped a bolt into the other side to close up the holes, re-installed it. Cheap fix and works fine.
If both manifolds are glowing red, you have a bigger tune-up issue to solve first.
Old Sep 5, 2007 | 11:12 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
My first thought were about timing when I read the original post. Give that a look and see where you are. Have you seen Lars Timing Paper? If not we can post a link to it for you. Pretty good read.
Old Sep 6, 2007 | 09:58 PM
MI-CORVETTE
Thanks again guys for the help and if someone could get me that link to Lars paper Eddie was referring to, that would be great. The wierd thing is that the car seems to run well and the temp guage usually only gets up to about 175 or so. Never has it been above 200 even with the glowing manifolds.
Old Sep 6, 2007 | 11:20 PM
DARROW's Avatar
DARROW
Do you have stock manifolds
Old Sep 6, 2007 | 11:25 PM
Chandler's Avatar
Chandler
Hello, long shot, are the catalytic converters clogged?
To Red hot manifold!
