Header gaskets
Old Sep 5, 2007 | 08:36 PM
nw2571's Avatar
nw2571
Default Header gaskets
Anybody got a good header gasket that they've had success sealing with? I've got longtubes on my '68 and paper gaskets aren't doing a thing. I was going to order a Mr Gasket Copperseal. 0.043" copper gaskets with embossed rings around the ports. Anybody used these gaskets? They sound like a pretty good product and they're half the price of dead soft aluminum gaskets.
Any luck with studs vs bolts? One trick I've seen used to keep bolts tight is to increase the grip length of the bolt (ie increase the length from under the flange to the first engaged thread) in order to put more preload or stretch into the bolt. That's the biggest problem with keeping header bolts tight because you've gone from a nice thick flange on your manifolds to a real thin flange on the headers. I can't seem to find any kits already available. Might be fabricating something this weekend!
Old Sep 5, 2007 | 10:15 PM
Hybrid117's Avatar
Hybrid117
stage 8 locking header bolts might help
Old Sep 6, 2007 | 09:37 AM
nw2571's Avatar
nw2571
Those Stage 8's look way to gimmicky to me. Have they worked for you?
Old Sep 6, 2007 | 09:53 AM
75 Hot One's Avatar
75 Hot One
I've had very good experience with Mr. Gasket copperseal & Stage 8 bolts. The gaskets hold very well. The Stage 8 bolts are a pain to install & remove because of the locks & snap rings- they require a lot of patience & take time to install & remove. Also, I had to grind off some material to fit the locking washers because of the small clearance between some bolts & the header tubes. But, once installed, they worked well.
Old Sep 6, 2007 | 10:20 AM
Phil Zell's Avatar
Phil Zell
allen head bolts and dead aluminum header gaskets.
With the allen head bolts you can get the 3/8 drive allen socket so you can crank them tight.
Mine have been on for over a year and have not needed tightening.
Just my .02 worth
Old Sep 6, 2007 | 01:58 PM
ED DINAPOLI's Avatar
ED DINAPOLI
No gaskets at all. Just use high temperature sealent. Headers are on for 5 years no leaks and no gaskets to blow.
Ed
Old Sep 6, 2007 | 04:44 PM
dewcustom's Avatar
dewcustom
use these from Percy's and stage 8 bolts
Old Sep 8, 2007 | 12:58 AM
RIJVETTES's Avatar
RIJVETTES
I blew out the regular Felpros in 3 weeks. Just installed the Summit coppers- just like the Mr Gaskets. No problems or leaks so far.
Old Sep 11, 2007 | 01:09 AM
69elky's Avatar
69elky
Default Percy's
I second on the Percy's,I have hedders on my 79 Corvette and my on my 69 El Camino.I have used Mr.Gaskets for as long as I have had hedders and I had seen the Percy gaskets in my local Auto Zone and I needed to replace the gaskets on my El Camino due to the usual breakdown of gaskets and bought them and they are holding up also I safty wire my hedder bolts.Drilled them and use 032"wire,I am an aircraft mechanic,just seemed natural to me to do so!When the Corvette comes due for new gaskets it will get the Percy's.Later Geno
To Header gaskets
