Rear main seal.
Old Sep 6, 2007 | 01:26 PM
Ajaxxx's Avatar
Ajaxxx
Cruising
Default Rear main seal.
I'm going to attempt to replace my rear main seal on my 81. I checked other posts on this subject and it looks straight forward. My question is what is the best type of seal to use? One piece or two? I was looking at Fel-Pro Performance FPP2912 from summit for $22. bucks. It's a two piece. All suggestions are welcome. Thanks.
Old Sep 6, 2007 | 01:30 PM
Durango_Boy's Avatar
Durango_Boy
I think you have to have a different style block to have a one piece rear main seal.
Old Sep 6, 2007 | 01:39 PM
BerniesVette's Avatar
BerniesVette
If your engine has a one piece rear main seal, that is what you have to use. My 79 had a two piece seal so that is what I had to use to replace it.
Bernie
Old Sep 6, 2007 | 01:42 PM
Ajaxxx's Avatar
Ajaxxx
Cruising
I was looking at summit again and I do need the two piece. Thanks for your replies.
Old Sep 6, 2007 | 02:10 PM
Paul L's Avatar
Paul L
You're fortunate. To replace the one-piece seal you need to drop the transmission.
Old Sep 6, 2007 | 02:37 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
For your pan gasket, be sure to use the Fel-Pro 1 piece. They're great.
Old Sep 6, 2007 | 02:48 PM
Durango_Boy
Oh, and don't buy a Fram oil filter. Wix is a very common and very good oil filter.
Old Sep 6, 2007 | 03:36 PM
desi's Avatar
desi
You might need the thin seal. I think they changed after 74... Be sure to double check.
Old Sep 6, 2007 | 03:39 PM
Edzred72's Avatar
Edzred72
CarQuest brand filters are made by Wix
Eddie
Old Sep 6, 2007 | 06:26 PM
NHRalph's Avatar
NHRalph
I believe one piece seals were from 1986 on, earlier 350's had 2 piece.
I usually get my filters at NAPA, they seem to filter better then FRAM, although you can get FRAM's anywhere.
Old Sep 7, 2007 | 01:28 AM
jackson's Avatar
jackson
You don't need "race" seals/gaskets for your 81 ... they won't seal any better but will cost alot more. Why not just go to local parts store?
These are correct for an 81 sbc:
  • Rear Main Seal = Felpro BS40013 ( if your crank has a groove worn in it by seal substitute w/ offset lip rms BS11829-1 )
  • One Piece Oil Pan Gasket = Felpro OS34510T ( it's a nice 1-piece rubber gasket to retrofit '75 thru '85 but it's not a race gasket )
Old Sep 7, 2007 | 01:41 AM
Ajaxxx's Avatar
Ajaxxx
Cruising
Thanks Jackson, I'm going to use your advice on part numbers when I order. Thanks all for your advice!
Old Sep 7, 2007 | 09:03 PM
1982CorvetteDude's Avatar
1982CorvetteDude
Dropping the oil pan, did you guys have to unbolt anything to do with the slave cylinder or steering components to get the oil pan out?
Old Sep 7, 2007 | 09:06 PM
Dirtbuster1's Avatar
Dirtbuster1
Instead of buying the seals seperate, by a complete gasket set. You should find one for around 40 dollars or less. Felpro!
To Rear main seal.
