Headlights?
Old Sep 6, 2007 | 06:43 PM
63_GrandSport's Avatar
63_GrandSport
Default Headlights?
The head lights wont come up on this car I am buying. The dimer swith is bad will that make the lights not come up?
Its a 78.
I also was woundering about puting true dual exhaust on it. Do I still have to put 2 catalytic converters on it?
Thanks for any help you can give.
Old Sep 6, 2007 | 06:52 PM
...Roger...'s Avatar
...Roger...
The dimmer switch will not keep them from coming up.Did you try the pulldown overide switch?
Old Sep 6, 2007 | 07:01 PM
Duke94's Avatar
Duke94
On the duels, you'll have to check local laws on smog requirements. If you have annual smog checks, you'll be leaving the stock exhaust with the cat.
On the headlights, sounds like a vacuum relay valve or the light switch. As stated, does the manual over ride work? If so, that would eliminate the relay valve.
I take it you bought the car?
Old Sep 6, 2007 | 07:02 PM
63_GrandSport
No I did not. Where is that located at? I am dont know that much about the way they work so any info helps.
Old Sep 6, 2007 | 07:06 PM
...Roger...
The pulldown is just under the steering column.Here is your vac system.
Old Sep 6, 2007 | 07:13 PM
63_GrandSport
Thats helps alot. I will try the switch tomarrow.
Old Sep 6, 2007 | 07:15 PM
Duke94's Avatar
Duke94
Happen to have a picture. Under dash left of steering column. It's the black thingy sticking down.
Old Sep 6, 2007 | 07:19 PM
63_GrandSport
Thats helps.
Old Sep 6, 2007 | 07:24 PM
...Roger...
If the pulldown doesnt bring them up(and theres a good chance it wont)let us know and we can walk you through how to diagnose it.
Old Sep 6, 2007 | 08:22 PM
63_GrandSport
I sure will thanks alot
Old Sep 9, 2007 | 07:08 PM
63_GrandSport
It worked. I pulled the over ride switch and they came up and on. So would it be the dimer switch and the light switch?
Old Sep 9, 2007 | 07:23 PM
Duke94's Avatar
Duke94
If you look at the vacuum circuit, there's 2 ways to get vacuum to the headlight relay valve. Either the over ride or the light switch. Dimmer switch has nothing to do with the vacuum controls.
Old Sep 9, 2007 | 07:41 PM
63_GrandSport
I think the light switch is bad as well. It just dont feel right when I pull it out. But that could be what it is then.
Old Sep 9, 2007 | 07:59 PM
assassin 420's Avatar
assassin 420
Mine just did the same thing. When you pull the headlight switch, the lights come on but don't pop up. It seems like the switch got easier to pull, like some came disconnected. I tried the overide as you suggested and they popped right up. Must be the headlight switch.
Old Sep 9, 2007 | 08:22 PM
63_GrandSport
Mine is really easy to pull.
Old Sep 9, 2007 | 08:47 PM
...Roger...
Here is a pic of the headlight valve from the inside.You can see the little tab close to the vac. ports that moves the vacuum valve.The little tab goes in a small groove in the plastic slider that the **** moves when operating the switch.Either the plastic breaks or the tab bends over.Just thought you might want to see what it looks like.
Old Sep 9, 2007 | 09:01 PM
63_GrandSport
I am going to order one whats the best place to get parts for my 78? I have a Corvette America catalog are they good to deal with?
To Headlights?
Old Sep 9, 2007 | 09:37 PM
76 VETTE's Avatar
76 VETTE
I just had the same problem on my 76. lights would come on but not pop up.I have mine out and there is a rattle in it. The first thing I noticed was it came out too easy when i pulled the switch. I am ordering from CA never had any problems and their shipping is super fast.
Old Sep 9, 2007 | 10:49 PM
guitarcrazy02's Avatar
guitarcrazy02
Welcome to corvettes and the world of vacuum controled EVERYTHING!
Old Sep 10, 2007 | 09:58 AM
Young69Owner's Avatar
Young69Owner
You can start by listening for vacuum leaks. Find all those little black hoses and look for dry rotting. Also, listening for air blowing right after you turn your car off.
