Problem starting when Hot!
Old Oct 23, 2007 | 09:04 PM
Ironcross's Avatar
Ironcross
Default Dont Do Anything Before This
Check your charging system. {alternator} THERE is noting wrong with your starter. Low battery voltage will cause a problem like your experiencing.. The alternator must put out at least 13.6 volts minimum. Easy to check with a volt meter.
