Overflow Radiator Resevoir Level
Old Sep 8, 2007 | 03:24 AM
Chris Farrer's Avatar
Chris Farrer
Default Overflow Radiator Resevoir Level
I have a '72 BB Auto which has the sausage shape overflow reservoir tank. Each time I go out I fill the overflow to about 1" from the top and if I stop during a trip there is some leakage from the overflow pipe.
The engine does not get overly hot.
I have read many posts about this question and presume mine finds the correct level however you can't see inside what that is.
On late model cars there is a plastic bottle with a high/low or hot/cold mark so you can see where it should be.
I have tried different radiator caps, all with the same result. If I stop there is some loss of fluid probably 1/2 litre.
How can I be sure there is enough fluid in the reservoir.
Old Sep 8, 2007 | 09:02 AM
phclub's Avatar
phclub
New England Events Coordinator
Default small block same problem fixed
I had this problem, bought a new 15lb aluminum compatible cap, made sure the air seals around the rad were all there and tight. The car is cool and the tank only spits a bit on a hot day. About half way fill the tank is what the small block works best at, but I am sure each car may need a slightly different level. I run the car until the fluid is only lower than the half way mark looking inside the tank.
Old Sep 8, 2007 | 09:05 AM
shafrs3's Avatar
shafrs3
Let it seek it's own level and if it still runs cool don't worry about it.
Old Sep 8, 2007 | 09:22 AM
Chris Farrer
Thanks for your advice. I would still like to know if there is any fluid in the reservoir after the leakage and you can't see inside. Is there a way to check without pulling the tank out to check.
Old Sep 8, 2007 | 09:35 AM
69vettester's Avatar
69vettester
I have that same tank, and have used it with the original cooling system and a new alum. & spal fan system . For 8yrs, The resevoir has "Always" stayed at 1/3rd full level. If I found the resevoir Empty, Id be worried I had a leak somewhere?
PS...If I fill the resevoir to more than 1/3rd..it just returns to that level as soon as the engine runs at operating temp.
Old Sep 8, 2007 | 09:58 AM
72ragtop's Avatar
72ragtop
usually have it 1/3 to 1/2 full. only time i got any overflowing thru the hose is when i changed radiator hoses and system purged
Old Sep 8, 2007 | 10:32 AM
Chris Farrer
Thank you for the advice. It seems my overflow is in the same ballpark so that's good to know. These things ****le at you a bit and where I live there there are not many Corvettes to compare with.
Old Sep 8, 2007 | 11:55 AM
Mike Ward's Avatar
Mike Ward
Read through this thread to understand how the system works and why you must not overfill it!
http://forums.corvetteforum.com/show....php?t=1803785
Old Sep 9, 2007 | 07:58 PM
Chris Farrer
Thanks Mike that was interesting reading. I'm afraid I am not very mechanically minded and need things spelled out for me.
Regards,
Chris
To Overflow Radiator Resevoir Level
