Ok so how do you test the TPS?
Old Sep 9, 2007 | 08:02 PM
Ibuyvettes's Avatar
Ibuyvettes
Default Ok so how do you test the TPS?
Need to know how to test the throttle position sensor on an 82.
Oh and what setting should I set the voltmeter on?
Old Sep 10, 2007 | 03:25 PM
Durango_Boy's Avatar
Durango_Boy
Here's a bump for you.
Old Sep 10, 2007 | 08:38 PM
Hotrod406's Avatar
Hotrod406
DC volts. full throttle should be 5v. One wire is 12v, one is ground, and ther other varies from around 0 to 5v.
Old Sep 11, 2007 | 06:41 PM
Ibuyvettes's Avatar
Ibuyvettes
What about no throttle 0 volts? which terminals should I connect to?
Old Sep 11, 2007 | 07:16 PM
Hotrod406's Avatar
Hotrod406
There's only one wire that varies. Hook one end of the meter to a ground and the other end to that variable wire.
To Ok so how do you test the TPS?
