GM HEI in a 74 question ???
Old Sep 10, 2007 | 07:24 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default GM HEI in a 74 question ???
I have just switched from the original points TO a GM HEI distributor in my 74 model 454.
Do I leave the (74) R44T spark plugs and gap setting?
OR switch to ________ plugs and gap them at _______ ?
Thanks...............
Old Sep 10, 2007 | 08:33 PM
Roughrider's Avatar
Roughrider
Since the engine is the same...only the method of delivering the spark has changed, I'd stick with the stock spark plug application but try opening the gap to .040" or .045".
Old Sep 10, 2007 | 09:06 PM
crazywelder's Avatar
crazywelder
Fred, Your gap width is determined by the ignition coil you are using. If you are using a stock coil, gap the plugs at .035". Higher output coils will allow you to open the gap wider. However, a wider gap with a stock coil will put more load on the coil and most likely shorten the coil life since the coil needs to work harder to jump the wider gap.
Being able to run a larger gap will improve combustion.
Old Sep 10, 2007 | 09:47 PM
jackson's Avatar
jackson
To GM HEI in a 74 question ???
