Tuning & Timing mark jumps
Old Sep 14, 2007 | 01:54 PM
radiojoe's Avatar
radiojoe
Originally Posted by BigBlockk
The reason you couldn't seat the distributer is becuase of the oil pump drive shaft. The slot in this shaft didn't line up properly with the distributer gear key. Do your TDC drill on #1 cylinder again. If the distributer doesn't seat you will need to rotate the oil pump drive shaft a little with a screw driver. Keep making small adjustments until it drops into place.
BigBlockk
Later.....
Sorry if this is a silly question- but to clarify...
When the distributor does seat, it will always turn the rotor some right? I made mark on the distributor housing of where the #1 post is, so when I seat the distributor, should the rotor point to that mark, then once it's seated it won't be pointing directly at it. Or, should the rotor point to that mark after it has been seated and rotated?
Thanks!
Old Sep 14, 2007 | 01:55 PM
Cvman74's Avatar
Cvman74
The reason for the backfire is you probably had the dist. 180 degrees out..just as long as it's pointing in the general direction of the mark you made..it can be fined tuned on start up ..
Old Sep 14, 2007 | 02:28 PM
radiojoe's Avatar
radiojoe
BigBlockk
Later.....
I rotated the oil pump drive shaft with a screw driver, but noticed that is was very loose- like the drive shaft would go back and forth and around like whatever it was attached to wasn't tight. Is this normal??
Old Sep 14, 2007 | 02:33 PM
BigBlockk's Avatar
BigBlockk
Thanks!
Ideally, when pulling a distributer you should use three marks. The first is down by the clamp at the base. This will reference the distributer to the manifold.
Next, take the distributer cap off and mark where the rotor is pointing on the distributer body. Now, remove the distributer clamp.
As you raise the distributer out of the engine the rotor will turn. When the rotor stops turning mark the distributer body where the rotor is pointing. Remove the distributer from the engine.
Using these three marks and paying attention to the oil pump drive shaft orientation, you should be able to get the distributer back in the engine in exactly the same spot as before.
BigBlockk
Later.....
Old Sep 14, 2007 | 04:34 PM
Durango_Boy's Avatar
Durango_Boy
BigBlockk
Later.....
This is how I do it every time. If a new distributor is going in it makes things more difficult but for the same one it's cake.
Old Sep 14, 2007 | 04:50 PM
babbah's Avatar
babbah
BigBlockk
Later.....
thats' the way I have done it
Old Sep 14, 2007 | 05:39 PM
radiojoe's Avatar
radiojoe
Default Update
Well- I got the distributor back in properly, dwell, and base timing set, although I still do have timing scatter, though it doesn't seem to be as bad as before I got the distributor shimmed. Going to have to check the breaker plate and hopefully I won't have to replace the timing chain, looks like that is quite the job according to my manual. Well, it can at least wait til winter anyway.
Also replaced my oil pan gasket with the one piece felpro, but still looks like I got a leak coming from the rear main seal. Yikes, might have to wait 'til after the car show this weekend!
Old Sep 14, 2007 | 06:31 PM
427-390's Avatar
427-390
Originally Posted by lars
A 5-pound hammer is my #1 Tuning Tool - any Vette can be tuned with a hammer... ask anyone who has attended a Tuning for Beer World Tour Event...
I've attended a TFB session, I can attest!
