heads on 75
Old Sep 11, 2007 | 10:09 PM
smon's Avatar
smon
Default heads on 75
i need to get new heads for a 75 vette- l-48 summit 1102 cam, edelbrock per. intake.
i dont need the best or really high compression. i want to boost performance some, but need to keep the price down as much as possible.
what cc and brand would you guys recommend. i dont know what im looking at here so any help would be great.
thanks, sean
Old Sep 11, 2007 | 10:15 PM
chris75stingray's Avatar
chris75stingray
the originals are 76cc so you can get either 64 or 56 cc depending on how high you want the compression to be.
steel heads will be cheaper than aluminum. the 75 heads have bad flow so anythings an improvement. maybe just a replacement from an earlier 350 .
Old Sep 13, 2007 | 09:59 AM
smon's Avatar
smon
any other ideas?
Old Sep 13, 2007 | 10:58 AM
jackson's Avatar
jackson
Originally Posted by 75vettehelp
any other ideas?
Summit P/N SUM-152123 http://store.summitracing.com/partde...476+4294785058 with Felpro 1094 gaskets will have better quench & bump OE L48 compression to about 9.3:1, work well w/ your 1102 cam, bolts up to what you have, new, assembled, affordable $650/pr
Old Sep 14, 2007 | 04:24 PM
smon's Avatar
smon
i found these on ebay. seem like a good price, but are they crappy?
http://cgi.ebay.com/ebaymotors/HIGH-...spagenameZWDVW
will this work wit hooker headers, 1102 cam, and edelbrock intake?
Old Sep 14, 2007 | 09:00 PM
chris75stingray
those casting numbers seem to indicate that those heads are for a 305. still a small block but i don't think they will flow very good on a 350
Old Sep 14, 2007 | 10:07 PM
75 Hot One's Avatar
75 Hot One
One of the first mods I made to mine was to install Dart II heads. They're now called Sportsman II by World Products & sold by Summit. They're available in 76cc & 67cc if you want to increase compression. Also available in cast iron or aluminum. Advertised to increase HP by 30 out of the box. A good investment.
Old Sep 14, 2007 | 10:48 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
You can get Dart Iron Eagles 64cc that'll bump that compression for only $500 a head. The sportsman II though are a great deal, and you really can't get alot more with that cam and intake. Have you though about bumping up to the L-82 cam?
Old Sep 15, 2007 | 03:19 AM
colin75's Avatar
colin75
Im Also Lookin For Heads And Ive Been Driving Myself Crazy Searching. I Checked A Local Machine Shop And They Recommended A Head Called Eq. They Have Various Cc And Runner Combinations. This Place Will Set Up A Set Of 64cc With 200 Intkake Runner For 600. Sounds Great To Me And Ive Been Researching And Alot Of Machine Shops Carry These Heads. Has Anyone Heard Of These Heads?
Old Sep 15, 2007 | 03:22 AM
colin75's Avatar
colin75
IM ALSO LOOKIN FOR HEADS AND IVE BEEN DRIVING MYSELF CRAZY SEARCHING. I CHECKED A LOCAL MACHINE SHOP AND THEY RECOMMENDED A HEAD CALLED EQ. THEY HAVE VARIOUS CC AND RUNNER COMBINATIONS. THIS PLACE WILL SET UP A SET OF 64CC WITH 200 INTKAKE RUNNER FOR 600. SOUNDS GREAT TO ME AND IVE BEEN RESEARCHING AND ALOT OF MACHINE SHOPS CARRY THESE HEADS. HAS ANYONE HEARD OF THESE HEADS?
http://www.lightningcylinderheads.com/index.html
Old Sep 15, 2007 | 08:32 AM
smon's Avatar
smon
what cc are the stock head that are on my l-48 right now?
Old Sep 15, 2007 | 08:40 AM
andylmusic76's Avatar
andylmusic76
i've been looking at doing this with my '77 l-48 heads. i want to upgrade to the old "fuelie" heads. they have bigger valves and are 64cc. they are relatively cheap on ebay.
Old Sep 15, 2007 | 11:05 AM
Red 69's Avatar
Red 69
thanks, sean
This is a purdy ggod deal from Scoggin Dickey
http://www.sdparts.com/product/SD806...RPMAirGap.aspx
The cost is $1084. This upgrade to a L-48 has been posted here. Hood clearance is obtained with an Holly avenger carb and drop base AC. If your budget will permit, go with a hydraulic roller cam. This is one thread about the upgrade that may help.
http://forums.corvetteforum.com/show....php?t=1805765
Old Sep 15, 2007 | 02:55 PM
smon's Avatar
smon
can i get just the vortec heads and install kit without the intake, or will an edelbrock performer work with these?
i found these seperatley off summit
http://store.summitracing.com/partde...232+4294838998
with this i have to buy bolts, gaskets, and do they fit up to my hooker headers?
or are these the same thing but come with gaskets,bolts and i can sell the intake.
thanks, just trying to keep the cost down as much as possible. $800-900 if i can
Old Sep 15, 2007 | 04:30 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Check out the Brodix IK 180. They run about $1000 but are a quality aluminum head. Your stock heads are 76 CC. The fuelly heads won't have acc. holes unless they are 1969 or 1970 heads and those are bringing big bucks. I have 2- 64CC 186 fuelly cores with accessory holes for $200 if you decide to go with iron fuelly heads. They are magnafluxed and guaranteed crack free and rebuildable.
Old Sep 15, 2007 | 10:06 PM
chris75stingray
i don't think intakes for standard and vortec heads are interchangable.
Old Sep 15, 2007 | 10:26 PM
TopGunn's Avatar
TopGunn
I haven't heard of those heads but I was told that 200cc runners are pushing the envelope with my motor combination, a ZZ4 with a mild cam. I bought some Brodix IK-200's and was ready to install them and also discovered that the intake would not fit them either. I exchanged them for IK-180's and like them very much, great heads!
To heads on 75
Old Sep 16, 2007 | 01:48 PM
jackson's Avatar
jackson
NO ... those have vortec intake manifold pattern & will not fit your intake [requires another (vortec) intake manifold or machine shop labor to make yours fit] ... also those vortec heads require different valve covers ... vortecs to L48 retrofit requires different rocker arms (or addition of guideplates), different intake & different valve covers ... the summit heads (SUM-152123) I suggested earlier fits what you currently have.
-edit- even when old intake modified to fit vortec ... it won't fit well ... poor port match.
Old Sep 16, 2007 | 03:38 PM
smon's Avatar
smon
thanks, i think im gonna go with the summit ones that you suggested jackson.
what rockers, rods, and gaskets should i get? anything else or will my headers, intake, and covers fit
sean
Old Sep 16, 2007 | 08:54 PM
63mako's Avatar
63mako
Too late Stingr69 just bought these!
