O-ring Calipers cure air problems?
Old Sep 12, 2007 | 03:08 PM
RunningMan373's Avatar
RunningMan373
Default O-ring Calipers cure air problems?
Changed the Disks and Calipers but did not shim about a month ago. Used original Lip seal calipers from SSBC. The system will get air into the brakes if driven. I know the rotors need to be shimmed, but with 150K on the rear bearings, some say end play in the rear spindles will cause the same problem, so shimming won't cure the problem. anybody have a like problem and go with O-Ring calipers as a fix and did it fix the air problem? Trying to deciede what rout to take on this. Don't really feel like pulling the rear trailing arms right now,, maybe in 6 mos when i get my working space together. Thanks,, C.
Old Sep 12, 2007 | 03:20 PM
...Roger...'s Avatar
...Roger...
If your runout is that bad it might wear out the O-rings in the caliper.
Old Sep 12, 2007 | 09:00 PM
RunningMan373
bump
I don't theink the runout is that bad,, just bad enough to cause a problem with the lip seal calipers,, like I said,, I changed all 4 disks as well,, anything over 1/100 of an inch at 5 in from center will cause a problem, on just one.
Old Sep 13, 2007 | 06:11 PM
...Roger...
Originally Posted by RunningMan373
bump
Have you narrowed it down to 1 caliper? Whatever caliper has the air will be the culprit.Maybe you can get by by shimming that one.
Old Sep 13, 2007 | 06:25 PM
RunningMan373
No,, i've been lazy. the Cars been sitting and I've been sitting. I am starting to believe these cars force to completely restore them, before you get to drive them. Trying to figure on what route to take.
Old Sep 13, 2007 | 08:24 PM
...Roger...
Your absolutely right.A big part of them have been driven without much mechanical attention.Most shops like to take them in for repairs but do more driving around than repairing because they dont have the patience or the expertise required for the C3.If money would have been spent more wisely on mechanical instead of paint the C3s as a whole would be in much better shape today."Pretty Sells"
Old Sep 14, 2007 | 12:24 AM
MN-Brent's Avatar
MN-Brent
If you get the O-ring conversion kit from VBP, it'll only set you back ~$150 and you'll be able to rebuild all 4 calipers yourself. Pretty cheap investment to see if this takes care of your issue.
Make sure your existing calipers are SS sleeved and in OK shape.
B...
Old Sep 14, 2007 | 01:44 AM
TXShark's Avatar
TXShark
I'm definitely a fan of the VB&P O-ring calipers. It cured my problems. The only downside is that I've gotten out of practice bleeding the brakes
Old Sep 14, 2007 | 04:27 AM
RunningMan373
OK, this is what I am going to do, and set in motion. I got 2 rear O-ring calipers on order, and a full set of front wheel bearings, Timkins. I will change the front bearings and shim the rotors to near 0 run out,, then shim the rear rotors to the same and put the O-Ring calipers on the rears incase of excessive end play. Then power bleed through with my motive. That ought to cure it,, and make it drivable.
Old Sep 14, 2007 | 08:38 AM
...Roger...
Sounds like a plan.
I would like to add GM allows up to .008 end play.End play over .001,.002 or .003 does not increase runout it only makes it almost impossible to accurately check.A new axle between centers that indicates 0 on both bearing surfaces and the rotor flange- will be 0 runout when install in the car with good bearings whether it has .001 end play or .008 end play.Once again with .001 end play you can check it and prove it....with .008 you can't. .......
Old Sep 18, 2007 | 03:01 AM
69elky's Avatar
69elky
Default VB&P "O"ring seals
Just my two cents,I am an original owner of a 79,L- 82 ,4 speed car and perform regular pm on it.With the brakes I would replace the stock lip seals,clean the bores,replace fluid(silicone)my preference .This was done on a yearly basis and the reason that started the vigilant process was leaking calipers.Three years ago I purchased an "O" ring seal kit from VB&P at the Orlando NCRS show/swap meet and this is the best mod I have done to date for me.My brakes have been trouble free,I have not had any issues with rotor run out yet.Also I have not gone to s/s calipers,still original ones on car. Later Geno
Old Sep 18, 2007 | 06:12 AM
RunningMan373
Sounds like a plan.
Yea,, the end play on the rears is probably gonna be pretty execessive, as the rear swing arms have never been rebuilt. That's going to make checking the runout difficult,, but I'll see what I come up with once I get the car up and the wheels off. I'll see what i can do w/o rebuilding the rear arms. I think with my best shim efforts and the O-ring calpers I can get it to work. Just want to enjoy all my work and DRIVE this thing!!!
To O-ring Calipers cure air problems?
