Help! decode rear-end
Old Sep 12, 2007 | 06:46 PM
Fonz69's Avatar
Fonz69
Default Help! decode rear-end
I have the cover off the rear-end for my vette and I need to know what the ratio is for sure.
I counted the teeth on the larger gear and there are 37
And on that gear it says
3733908 9-37 GM1 65 1A
I think they might be 3.90?
I am going with a muncie m20 and a 427 if they are 3.90 that would be allot going down the road at 70 mph huh? About 4200+ ?
Any help would be great.
Old Sep 12, 2007 | 07:02 PM
rihwoods's Avatar
rihwoods
Look for a two letter code...for example:
1969
FA= 3.70 heavy duty posi
FB= 4.11 " "
FC= 4.56 positraction
AP= 4.11 positraction..
Old Sep 12, 2007 | 07:11 PM
RPOL68's Avatar
RPOL68
9-37 indicates a 4.11 gear set.
Old Sep 12, 2007 | 07:19 PM
Gordonm's Avatar
Gordonm
GM never installed a 3.90 gear in a Vette. They are available but not GM. I agree on the 4.11 gears.
Old Sep 12, 2007 | 08:42 PM
Fonz69's Avatar
Fonz69
The rear-end is not from my 69 vette but a donor out of a 66 vette that was used in autocross events
The rear bottom reads FB 66
so originally it was a BB 427 4:11:1 out of a 66 vette
the guy I bought it from could not tell me for sure what gears where in it now.
Anyone have a way to decode that ring gear number?
Old Sep 12, 2007 | 08:45 PM
Fonz69's Avatar
Fonz69
Well if it is a 4:11:1 set that would be way too tall for highway use right?
Motor will be a 427 around 450-500hp
I was thinking of a 3:55:1 ??
Old Sep 12, 2007 | 09:44 PM
72LS1Vette's Avatar
72LS1Vette
You can get a pretty good idea by just putting a mark on the input and output shafts and tuning the input shaft. If it takes a little more than 4 turns of the input to get 1 turn of the output you most likely have a 4.11
I think a 4.11 is too much for the highway unless you have an overdrive transmission. I'm going to put 4.10 gears in my diff but only because I'm using a 6-speed trans with overdrive in the top 2 gears.
Rick B.
Old Sep 12, 2007 | 09:56 PM
Fonz69's Avatar
Fonz69
right thats what I did and it does not make it to 4 turns so I was thinking could be 3:73:1 ?
Old Sep 13, 2007 | 05:35 PM
Fonz69's Avatar
Fonz69
anyone be able to look up that ring gear number?
Old Sep 13, 2007 | 07:22 PM
Gordonm's Avatar
Gordonm
The numbers you listed are definitly for a 4.11. The ring gear is 3733908 and the pinion should be 3885945. A 3.70 gear should have 3737957 on the ring gear. See if you can count the teeth on the pinion. For a 4.11 it should be 9 and a 3.70 should be 12.
Old Sep 13, 2007 | 08:37 PM
Fonz69's Avatar
Fonz69
OK 4:11:1
With a 450-500hp motor and a m20 would the 3:55:1 be the way to go for all around use?
I am sure how light this car is it would still spin the tires all day
I am looking at a 1-3 hour cruise for a overnight ect... would it overheat going 70-75 down the highway?
I plan on a aluminum radiator and dual fans
Also side exauhst
Old Sep 13, 2007 | 09:22 PM
Gordonm's Avatar
Gordonm
Back in the 60 and 70s 3.55 to 4.11 gears were normal and the ygot driven all the time. 3.55 is a good combo gear for in town and highway. I ran a 4.11 gear with my M20 and it was steep on the highway. The 3.70s were better but a 3.55 would be even better. inow run an OD with a 3.70 gear. The OD brings it down to a 2.51 gear. You should not overheat providing everything in the cooling system is in good shape.
Old Sep 14, 2007 | 06:27 AM
Fonz69's Avatar
Fonz69
Thank you all for the helpfull information
To Help! decode rear-end
