Suspension question
Old Sep 13, 2007 | 01:28 PM
conway62's Avatar
conway62
Default Suspension question
I have a 71 BB with fiberglass front and rear spring. Also have Steeroids R/P setup and 17 inch wheels w/BF Goodrich Gforce redials.
The problem is the car handles awesome on a nice flat road. Once I hit a highway with mild ruts, the car wants to follow them badly. It will almost pull you into the other lane if your now holding on.
What is the cause of this? Could this be an allignment issue? The front end and all suspension is new.
Thanks in advance.
- Ron
Old Sep 13, 2007 | 01:47 PM
gyopp's Avatar
gyopp
A lot of the problem is the type of tires that you are running. That's a common thing even with C6's and C5's. The wide, flat tread pattern doesn't seem to fit with the grooves other vehicles make. My C3 is worse than the newer cars and I think it is because the car is so narrow that there is no way for the tires on both sides to hit the groove. When I drive on open highway I usually hug the center line and get out of the grooves.
Old Sep 13, 2007 | 02:28 PM
Z-man's Avatar
Z-man
There are a billion threads on this subject. IMO the symptoms are exaggerated with wide tires and/or loose steering components. The cure? A decent alignment for the highway (slight toe in) and good steering bushings, etc. If you have your alignment set up for autocross or the track, it will be squirrely on the highway. Go to a shop that knows about Vettes. After I had an expert align mine, I can cruise in any lane at any speed and those grooves don't affect it at all. Tire wear is nil...
Old Sep 13, 2007 | 02:47 PM
1stC3Vette's Avatar
1stC3Vette
Are the front and rear tire sizes the same?
Old Sep 13, 2007 | 06:07 PM
conway62's Avatar
conway62
The fronts are a little narrower than the rear. All the parts are new. Im thinking an incorrect allignment may be the issue.
Old Sep 15, 2007 | 08:55 PM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
I'd check the alignment. Sounds like you don't have enough toe-in.
Also check to make sure none of the steering linkage is sloppy (tie rod ends, idler arm, etc.).
Old Sep 15, 2007 | 10:13 PM
kayosnes's Avatar
kayosnes
I had a good aligment after installing steroids and fiberglas spring front and back (suspension package). I dont have that problem at all. i will go so far s to say may car now handles better in the corners, than most normal cars.
Alignment, alignment, alignment!
Old Sep 16, 2007 | 01:13 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
To Suspension question
