Broken Cable???
Old Sep 13, 2007 | 10:14 PM
Cosmo Kramer's Avatar
Cosmo Kramer
Default Broken Cable???
Anybody know what this broken cable is attached to? The one end is, obviously, attached to the steering linkage, but what does the cable do and what does the other end attach to?. Everything related to the steering seems to work fine.
Old Sep 13, 2007 | 10:45 PM
Cosmo Kramer
Is this the broken part?
http://www.zip-products.com/Corvette...35D7412D89562C
If so, what does it do?
Old Sep 13, 2007 | 10:47 PM
Jim Shea's Avatar
Jim Shea
I assume that we are looking at your 1970 C3. The broken cable is supposed to come from your 4-speed transmission. It should be connected to the reverse lever. When you shift into reverse the cable is supposed to shove that steering column lever all the way up. This should allow you to rotate your ignition key from the OFF position to OFF-LOCK. Thus locking your steering wheel and gear shift lever and also allowing you to remove your ignition key.
General Motors and Saginaw came up with this system to prevent anyone from moving forward (down the road) and being able to turn off their engine and locking the steering wheel.
Your lower column lever must be in the up position. Otherwise you would not be able to remove your ignition key. This also means that you can turn off your engine and lock your steering column at any time.
If the lower lever works its way back to a more horizontal position, you will discover that you can no longer remove your ignition key from the lock cylinder in the steering column.
Here is a paper that describes the system in detail.
http://jimshea.corvettefaq.com/wp-co...tems27JL04.doc
You need a new cable.
Jim
Old Sep 13, 2007 | 10:50 PM
Patrick73's Avatar
Patrick73
Missing cable is not related to your steering system. See Chapter 7 (transmission) of the AIM for full illustration of the interlock system.
Cable originally ran to your 4 speed transmission (Interlock Linkage Cable). When operational, the trans must be in reverse in order to remove key from steering column.
Common to see the system disconnected.
(Note: Jim S. gave a much more correct and detailed response than I! He is the guru on all things related to steering. He is a great resource and always willing to assist.)
Old Sep 13, 2007 | 11:43 PM
Cosmo Kramer
Jim.........Wow. Thanks for all the info. And, yes, I am referring to the C3.
So, as GM designed it, in a properly functioning system, the car must be in reverse to remove the ignition key and lock the steering column.
Well, I tried moving the column lever down by hand. There seems to be, however, a large "C" clip holding the lever in the up most position. You can see the "C" clip in the photo. The diagrams in your paper do not show the "C" clip. Is this the work of "Bubba?"
As the system is set up now, the risk I am taking is that, if the car is turned off while in motion, the steering column will lock and thereby potentially causing a serious accident. Correct?
Old Sep 14, 2007 | 12:22 AM
Z-man's Avatar
Z-man
Well, if that clip holds the lever in position, you should be fine. That's how mine is because I have an aftermarket transmission. Just don't turn the key off and move it to the locked position while you are driving...you don't do that very often, do you?
Old Sep 14, 2007 | 08:14 AM
Jim Shea's Avatar
Jim Shea
That clip holds the lower bearing adapter in place. It has nothing to do with holding the lower lever. The lever may be rusted or somehow binding.
Removing the lower bearing and adapter as shown in the above picture may allow you to free up the shift tube and lower lever.
Admittedly, turning your ignition key all the way to OFF-LOCK while driving down the road is not something that you would normally do. However, when you build millions and millions of vehicles, you will find someone who might do it and then sue the manufacturerer.
In 1977 the Corvette went to the finger inhibitor system. You can turn the engine off, but you cannot get to OFF-LOCK until you depress the inhibitor lever. Not quite as idiot proof but requiring a two motion sequence to lock the steering wheel.
Jim
Old Sep 14, 2007 | 09:50 PM
Cosmo Kramer
Jim........Thanks for your help.
Obviously, anybody with a nickel’s worth of common sense would not turn the car off while in motion. However, given the litigious society we live in, the number of cars GM produces, and the large percentage of "less than intelligent" individuals out there, it's not surprising the GM has to make the cars "idiot proof."
To Broken Cable???
