Help opening my door.
Old Sep 16, 2007 | 06:02 PM
feb18blacksunday's Avatar
feb18blacksunday
From: Boone NC home of 3peat National Champs ASU Mountaineers
St. Jude Contributor
Default Help opening my door.
Freakin door won't open. I've tried to push down on that latch inside the door but to no avail. Anybody got an answer?
Old Sep 16, 2007 | 06:10 PM
Al77Vette's Avatar
Al77Vette
Roll down the window.
Get a long screwdriver.
Don't know the exact spot, you need to probe the striker mechanism on the inside of the door until it clicks. Don't use a lot of pressure and don’t twist the screwdriver when probing.
Old Sep 16, 2007 | 06:34 PM
feb18blacksunday
I've tried that. Not happening.
Old Sep 16, 2007 | 06:47 PM
Al77Vette's Avatar
Al77Vette
Does the inside lock button move? Is it stuck in the lock position? If so, this works for me. Sometimes I have to play with the inside lock button and inside door handle while probing.
Old Sep 16, 2007 | 06:49 PM
SIXFOOTER's Avatar
SIXFOOTER
Pull the seat, pull the door panel.
Push down on the end of the lever in the circle
Old Sep 16, 2007 | 11:11 PM
feb18blacksunday
Yea I've been trying to get that one. However I still can't get the thing to open. I've got another latch and I've been trouble shootin with it, still can't get it to open.
Old Sep 16, 2007 | 11:56 PM
SIXFOOTER's Avatar
SIXFOOTER
Sounds like its locked. See the big rod above the circle? pull it down or work it up and down, then push the lever down
Old Sep 17, 2007 | 12:21 AM
feb18blacksunday
I'll try that tomorrow.
To Help opening my door.
