Vacuum leak
Old Sep 17, 2007 | 11:42 AM
jbaron's Avatar
jbaron
2017 C3 of the Year Finalist
Default Vacuum leak
Hey all,
Is the best way to check for a leak using a gauge? If so where do I connect it?
Old Sep 17, 2007 | 12:37 PM
S489's Avatar
S489
get a "TEE" and some vacuum hose. remove one of the vacuum lines connecting to the manifold like the one in front of the distributor supplying vacuum to the headlights, then insert the TEE with the vacuum gauge on the branch of the TEE. now, with the engine running, remove and cap vacuum lines from the top of the engine and note change in vacuum reading (if it's a really bad leak, you won't need gauge for this). this should help you track down the offender; once there, any leak test procedure depends on the component.
post progress for more help . . .
Old Sep 17, 2007 | 06:45 PM
Duke94's Avatar
Duke94
There are some tech articles on the vacuum system on the site (along with a ton of other info).
http://lbfun.com/Corvette/Tech/vettetech.html
Old Sep 17, 2007 | 08:56 PM
kdf1986's Avatar
kdf1986
Duke94, thanks for the link. I found a tech help article for something I was looking for.
kdf
To Vacuum leak
