jumped time?
Old Sep 17, 2007 | 05:11 PM
painterman52's Avatar
painterman52
Default jumped time?
I`ve got a 383 with about 6000 miles on it. It eas running perfect then I felt a little change. I was just going 35 mph. When I stopped the idle was at 1600. I took off and it was not right I gave it gas and got a backfire. Under any load there was a lot of pinging. I reset the timing, had to move the dist a lot. It is running fine now. If it jumped time will it now stay where it is or am I driving a time bomb. What do I need to do to make it right?
Old Sep 17, 2007 | 06:23 PM
Jims79's Avatar
Jims79
I would pull the distributor and check the timing chain. something is not right. why wait for something bad to happen far from home.
Old Sep 17, 2007 | 06:44 PM
...Roger...'s Avatar
...Roger...
If it jumped time meaning the timing chain jumped I dont think it would be running "fine".Was the distributor loose,could it have moved on you?Did the mech. advance stick.Did you have to retard the timing(push the vac. adv. can towards the firewall)?
Old Sep 17, 2007 | 08:57 PM
painterman52
The distributer was not loose, and yes I had to turn it way towards the firewall, It`s running good now, but I don`t think I can trust it.
Old Sep 17, 2007 | 09:02 PM
...Roger...
Sounds like you had to retard it.Your advance weights might have stuck for some reason.You can check that with a timing light or by removing the cap.
To jumped time?
