Engine Upgrade and Vortec questions....
1980 l82 with Hooker SC side pipes and q-jet
1: what kit should i buy? http://www.sdparts.com/categories/en...dHeadKits.aspx
Im keeping my stock l82 low end, im just changing the heads and intake?
2: with my stock low end, any guesses on how much power i will be making?
3: I want to keep my q-jet but is that a bad idea? (i have had no problems with the Q at all) Im pretty sure it will fit under stock hood with the rpm air gap and a drop base but i might upgrade to the l88 hood.
lame .420 lift cam.. a testament to the good design of the heads.
I'd re-cam the L82 and strap on a C&S or Race Demon carb...
Stock Comp Ratio on the L31 was 9.6:1...headers if you don't have'em..
I'm traveling and so don't have my manuals in front of me - but if you're changing from a 76cc to head to the Vortec at 64cc this is an increase of 1 pt in compression.
The RPM intake is really only needed if you're turning REGULARLY over 5500 RPM. I'd go with the stock Vortecs and the Performer intake - along with High Energy-type cam in the .450 lift range.
I'd estimate power at about 330 - 350HP at the flywheel depdending on the cam selected.
.100 lift..70/49
.200 lift..139/105
.300 lift..190/137
.400 lift..227/151
.500 lift..239/160
.600 lift..229/162
Perhaps you're thinking about Double Humps falling flat..flow wise at
.450.... I'd lift from .525 to .560... At a theoretic average of 2 horsepower for every 1cfm of flow you'd be giving away 24hp if you stopped at .450 lift..
Reher/Morrison Racing suggest when chosing a cyclinder head
that you concern yourself with CFM/flow of Peak lift and .100 below
peak lift as this is where your valves will spend a majority of their
time. To position the valves near the heads peak flow in a maximum
effort engine you spec your cam's peak lift slightly above peak flow.
Stock Double Humps do have a limited CFM flow...there's just not
any appreciable increase in CFM at .500 & .600 in stock configuration.
you might want to ask-around the Forum to see how-wrong I am.....
As-stated above, heads without a better cam won't provide nearly as-much power as is possible, just-as a cam-swap w/o switching heads isn't optimal:
vortec-heads with a decent mid-range cam (something-like CompCams' 268H ? ) would make good power & torque below 5500 RPM, return better'n-average MPG, and have civil road-manners, too.
vortec heads is a square flange manifold # EDL-7516, to use your Q-jet you would have to use the low rise performer vortec # EDL-2116 or
look for another manifold brand. I would agree with the rest if your
going to pull your engine down far enough to change heads buy
a more modern high lift cam, and go with the highlift version of
scoggins vortech heads. This lunati Cam/Lifters would give you the right amount of duration with good lift LUN-60103LK. it would require the high lift vortech
heads. the standard head is only good to around .480 lift
www.summitracing.com
Very interesting note regarding cam selection - I'll have to think about that for a bit.
Completely agree regarding the camel humps unless huge investments are made in porting.
or
http://users.erols.com/srweiss/tablehdc.htm#Chevy
2 sites are listing similar flow data for the Vortec L31's...
or
BUT - good thoughts and maybe I need to re-examine. I've got a buddy with a set of stock Vortecs that has been dyno'd - I'll see if he's willing to do a cam/spring swap (free machining by me
) and see what we get.
Donny in C2 is running 13.47 @ 104 w/ similar stock cam.
It will work well with the higher CR of the vortecs.
Still, i'd change the timing chain!
Not a lopey big block by any means but good for some applications. -Mark.
The L31 350 Vortec Engine will make 440hp with a cam change and
minimal preparation. The LT4 Hot Cam.. sold by GM, lifts with reliability
and longevity to .525.... the LT4 Hot Cam springs are std. on the ZZ4
and are very inexpensive... about $40 per set at Pace Performance.
It is an expensive upgrade to add a roller cam to an old school flat tappet block. I doubt that is in the budget here.
-Mark.
Check my quote...Never said the Hot Cam was std. on the ZZ4... said the Hot Cam springs were std...they are GM part #12495494
here's the proof:
http://paceperformance.com/index.asp...D&ProdID=24732
230dur @ .050
110 LSA
stock lift is .489
I'd run this cam with 1.6 rockers instead of the stock 1.5's...this would
give you a corrected lift of .522. I'd run this cam with the LT4 Hot Cam springs... on pocket ported Vortec L31's with headers. Shave the L31 heads to bring compression into the 9.4 to 10.00 compression range.
Cheap good flowing heads, cheap good springs, cheap good Hydraulic
Cam...hell of a good upgrade on a budget.
right back
IMHO I think you're building unrealistic HP expectations based on my experience given a stock L82 lower end, and going the route your offering doesn't make for a very streetable engine.
Number 1-
http://www.carcraft.com/techarticles...ock/index.html
Number 2- http://www.popularhotrodding.com/eng...ock/index.html
Number 3-
http://www.speedomotive.com/ps-414-6...er-engine.aspx
Speed-o-Motive is selling a 450hp L31/350 as a crate motor...
Your machine shop can't figure out how to do that once??
2 different magazine staffs have achieved those levels..with nominal preparation... is this rocket science to you??
Some of the Dirt Cars I've wrenched on started with the L31 based GM Circle Track 350 Crate Engine... and have knocked on the door
of 500hp after mild porting.... with L31 Vortec Heads.
The cam I've suggested above and the one's in the articles above-
all streetable... the 230 dur @ .050 Engle is only a 270 duration total
cam with a slightly more aggressive LSA than Lingenfelter 112 LSA cams they sell for EFI cars that don't like loping.... a 2 points tighter cam.
Stock 5.0 87-93 Mustangs came with 266 duration cams from the
factory.. so I'm having a little trouble with your complaint & "expertise".
Lifting the valves to flow 450hp worth of air/fuel mixture CFM is only
scientific if that's what you are trying to achieve... I don't really
understand what direction you are going but it's not what I would
choose...we're probably going to have to agree to disagree because
Im not going to agree with your suggestions.
