Temperature Sending Unit
Old Sep 19, 2007 | 12:55 PM
TopGunn's Avatar
TopGunn
Default Temperature Sending Unit
I just bought a new sending unit at Autozone, is there some issue with having to recalibrate the temp gage if I use this one?? Ecklers has a note on theirs that says it doesn't require the gage to be recalibrated.
http://www.ecklers.com/product.asp?p...6&dept_id=1249
Old Sep 19, 2007 | 12:58 PM
pws69's Avatar
pws69
The only vendor that I have found to supply accurate/compatible senders is Lectric Limited.
Old Sep 19, 2007 | 03:26 PM
TopGunn's Avatar
TopGunn
Ouch! Mine doesn't have the correct terminal on it either to match the harness, another tip off I guess. I see Lectric Limited has them with the correct one.
Thanks for the tip
Bill
Old Sep 19, 2007 | 04:12 PM
1stC3Vette's Avatar
1stC3Vette
I went through two other sending units before purchasing one that works from Lectric Limited.
Good luck,
Dino
Old Sep 19, 2007 | 04:31 PM
SteveG75's Avatar
SteveG75
And half the price of Ecklers.
Old Sep 19, 2007 | 04:48 PM
Edzred72's Avatar
Edzred72
Another satisfied Lectric Limited sender purchaser here
Eddie
Old Sep 19, 2007 | 04:51 PM
jim2527's Avatar
jim2527
Eddie
Same here. My IR temp gun confirms the sending unit and gauge are accurate.
Old Sep 19, 2007 | 08:41 PM
TopGunn's Avatar
TopGunn
Thanks everyone, got one on order.
Lots of stuff on his site, I never knew he was out there.
Thanks again!
Old Sep 19, 2007 | 09:32 PM
enkeivette's Avatar
enkeivette
I bought one from Kragen, works fine. Same style as the original.
To Temperature Sending Unit
