Power Steering Pump Removal
Old Sep 19, 2007 | 02:57 PM
Indynut's Avatar
Indynut
Default Power Steering Pump Removal
I'd like to take the power steering pump off my car for the weekend and go racing. Its straight line 1/4 mile and the pump has been giving my trouble. I'm short on time and wondered if I could remove it and just plug the lines and go racing. i have all winter to fix it up or change to standard steering but need a fast fix for this weekend!
Please the more info I get the better!
Old Sep 19, 2007 | 03:01 PM
...Roger...'s Avatar
...Roger...
You would probably be better off not plugging it but draining the system.The cylinder is going to make it tough to steer if it is full of fluid and plugged.
EDIT-If you dont want to remove the pump- just remove the belt and drain it.
Old Sep 19, 2007 | 06:07 PM
19LEW71's Avatar
19LEW71
I don't know what type of set-up you have---but could you remove that belt or replace it with-out running the pump or remove the pulley.
Just my 2 cents!
Old Sep 19, 2007 | 07:09 PM
SargeZ06's Avatar
SargeZ06
Just take the belt off the pulley. There is no need to remove the pump.
Old Sep 19, 2007 | 07:15 PM
Gordonm's Avatar
Gordonm
That is the easiest.
Old Sep 19, 2007 | 09:33 PM
rdrunnur's Avatar
rdrunnur
What about the P/S actuator?
Will it still work being on the car without fluid running through it?
Old Sep 19, 2007 | 11:10 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Try the archives in my profile/threads.
Take a look at http://forums.corvetteforum.com/show...power+steering
and:http://forums.corvetteforum.com/show...power+steering
Hope this helps,
cardo0
To Power Steering Pump Removal
