When I go cruising in my 79, the speedometer sometimes tends to bounce up and down. For instance, when i am cruising at 30 mph, the speedometer will bounce down to around 25 and up to about 40. It does this at all speeds but doesn't happen all the time. Can anyone help me figure out why this is happening?
This has probable been asked before and may be obvious (I've been tinkering with my 82 for a couple of years now so have much, much to learn)......can you remove the speedo cable at the transmission end and pull it out? Probably designed so that can't happen; keep it securely in the speedo.
Mark
No you can't pull it through from the bottom. There is a key on the end of the cable that slides into the back of the speedo and that's too big to fit through the sheath.
On my car, the lower cable went bad. Basically the transducer starts to go bad, and puts more tension on the lower cable until it eventually breaks.
I replaced it with one single cable. It's not necessary to take the dash apart to get it off. I was able to kneel down outside of car, and slide my left hand up under the dash.. Follow the cable up to the speedo, and push a little metel tab, and it releases the cable.
Pull it out into the engine bay, and the gommit in the fire wall will come with it. Put the gommit on the new cable, and fish back in the hold. Reach behind and just push the new cable onto the speedo, it just 'snaps' on. The other end screws onto the trans.
It took me about an hour to do it, if I had to do it again, it would take me about 15 minutes.
$14.xx at Autzone, probably less elsewhere. Just did the same on my '75 yesterday. Cheaper than a cable greaser tool and will probably last well beyond your interest in the car. Took me about 20 minutes to replace and I am larger than average and less talented than average.
How did you replace the cable? Did you access the cable from under the dash or what? 20 minutes to do this sounds great as I need to replace mine on my '76.
I bought the fitting to lube the cable but it didnt last long. I replaced the cable myself (79 4 speed) in about 20 minutes., and I am not a mechanic. Took the front seat out which made it a lot easier.LT
Best to put the front wheels on ramps or stands. That way you can get to the fitting on the transmission. Unscrew the ring at the transmission. Then get up under the dash at the rear of the speedo, where the cable goes in, there is a tab you can push down and pull the cable jacket out. The cable and jacket then can be pulled out through the firewall grommet (be careful if bubba has used the grommet to route a million wires, like on mine...)
