are half shafts enough?
Old Sep 20, 2007 | 05:37 PM
redc3's Avatar
redc3
Default are half shafts enough?
to keep the rear alive in a street car with some dot slicks?
Old Sep 20, 2007 | 05:39 PM
Durango_Boy's Avatar
Durango_Boy
I guess that depends on the condition of the rear end components and the HP of the motor.
Old Sep 20, 2007 | 09:31 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
In 76 (I believe) Chevy went from 2.5" to 3.0" diameter shafts. These later shafts are said to be stronger. Spicer zerkless U-joints would be a good idea.
It'd probably all hold up with dot slicks especially if coupled with an automatic.
But there's a reason you don't see a lot of IRS's at the drags,..and when they let go, it can be ugly.
Old Sep 21, 2007 | 09:08 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Depends on HP. Run solid joints too. I assume you'll be at the strip as well so run a stiff rear spring to help stop the rear from sqauting as much. People swear by Spicers but I haven't been happy with their quality lately. The plastic seals break on every u-joint and their not even mfg in the US anymore. I guess it's just brand recoginition. I like Neapco joints myself.
Old Sep 21, 2007 | 09:18 AM
Durango_Boy
Van, is there a national chain parts retailer that sells Neapco?
Old Sep 21, 2007 | 09:49 AM
Van Steel's Avatar
Van Steel
I don't know. Most chains sell Brute Force U-Joints which are made by Neapco. I use their Performance Dynamic joints. The brute force joints are good but not many people are fond of the red seals. Most would prefer black. We have all of our joints cryoed before we even get them.
Dan
Old Sep 21, 2007 | 09:56 AM
karioth's Avatar
karioth
unless your running very high HP, the shafts should be ok, aggree with other people about the U-Joints, the stock ones are hollow I believe and can get mangled. i would just try to run, if you break a shaft then you know you need heavier duty ones ^_^
Old Sep 21, 2007 | 09:59 AM
Durango_Boy
That's a problem though. If he breaks a shaft he'll have to deal with a destroyed undercarriage. The broken shaft acting like a propeller tearing up the battery box or passenger box and or fender well.
I think I would avoid all of that and just beef it up with nice joints.
Old Sep 21, 2007 | 10:42 AM
Frank_833's Avatar
Frank_833
Maybe you should go with 'full shafts'
Old Sep 22, 2007 | 12:49 AM
GrtDanes's Avatar
GrtDanes
any pics on the full shafts
Old Sep 22, 2007 | 11:04 PM
CorvetteDave01's Avatar
CorvetteDave01
That is a joke dude, and a bad one at that, lol.
Old Sep 23, 2007 | 04:06 AM
Solid LT1's Avatar
Solid LT1
I run the 1973 and later half shafts on my 72 LT-1 (12.28@117MPH on slicks.) Make sure the suspension is raised enough that trailing arms won't bottom on stops on a hard launch of the Vette. Your shafts will likely fail if the trailing arm hits hard against the bumpstop on a launch, NOTHING will live if the bump stops are banged into on a hard launch! Use a stiff rear shock, and don't put too heavy of a flywheel in your Vette. WARNING! I also have a very well prepped differential with a 4340 steel drivers side cap and 1/2 bolts to keep my carrier from exiting the housing when I abuse my Vette (on a VERY infrequent basis!)
Old Sep 23, 2007 | 02:27 PM
redc3's Avatar
redc3
id gueestimate 450 at the wheel and im thinking nitrous if i dont sell it. so ive got the spicers and wanted to put a sticky tire on it. i am capable of fabbing my own hoops for the shafts and that lead me to my question if the upgradded shafts are enough. maybe i should just go back to my vegas
Old Sep 23, 2007 | 04:40 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
If you plan on 450 RWHP plus nitrous and slicks you will need a Tom's setup or backhalf the car and go with a Ford 9". The stock diff, halfshafts and spindles will not take that kind of use very long.
Old Sep 23, 2007 | 08:48 PM
73jst4fun's Avatar
73jst4fun
Also add some half shaft loops to protect your azz and other body parts. A broken shaft can do some real damage and the battery box isn't going to save you....
Old Sep 23, 2007 | 08:54 PM
David Ey's Avatar
David Ey
and put one on the main driveshaft too
Old Sep 24, 2007 | 11:26 AM
Van Steel's Avatar
Van Steel
At least upgrade to the 30 spline kit
http://www.vansteel.com/index.cfm?fu...&SubGroup=1878
To are half shafts enough?
