Hood Latch Cable Strap Location.
Old Sep 21, 2007 | 01:34 PM
Durango_Boy's Avatar
Durango_Boy
Default Hood Latch Cable Strap Location.
I need a pic of the hood latch cable that's on the hood in the early C3s. There is a strap that holds the cable up to the hood in the center and it's screwed or bolted in place. I have an after market hood that was not designed for this style of latch system so there is no hole for said screw.
I just need a pic for a rough location for this temporary hood latch cable.
Thanks guys.
Old Sep 21, 2007 | 03:52 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Is '76 early enough?
Old Sep 21, 2007 | 04:08 PM
Durango_Boy
So long as it's the old style latch system then yes that would be fine. Mine originally had the system where the latches and cable are on the firewall. I don't know what year they switched, but I converted to the older style latches that are mounted to the underside of the hood and have a cable connecting them.
I just need a pic of where that cable attached to the underside of the hood.
Old Sep 21, 2007 | 05:19 PM
Duke94's Avatar
Duke94
71'
Old Sep 21, 2007 | 05:21 PM
Durango_Boy
That helps a lot buddy, thanks.
To Hood Latch Cable Strap Location.
