Twin Spal question
I'm a cccuk member and have posted questions regarding twin spals with BB vettes before with reply about the fans but nothing regarding installation into a BB vette, as i don't think any u.k. members have done it.
I fitted a BCI twin fan about three months ago, after a flex-a-lite fan exploded and decided to exit via the new high rise hood i fitted 6 weeks earlier
The fit went well with no problems for a few weeks, then for some reason the fan relays both packed up on the way back from a show on a quite hot day in traffic, well for the u.k. anyway about 26 deg c. As most of you BB owners know they do tend to run hot at times up to 200 deg f
The relays fitted are made by TYCO and i wondered if they have been known to fail in the past, or was it just down to my poor positioning at the time on the inner fender wall in front of the the master cylinder.
I have moved them now in front of the rad so as to not get any hot air from the rad circulating around them.
Sorry didn't tell you i've got a 454 cu in + 30 with flat top pistons, stock rad (brass) edelbrock performer rpm heads and intake & 750cfm carb. It puts out about 370 hp and 365 lb ft
Thanks Peter
I've just seen where you are from. I lost my virginity on the beach at Southend lol
P.S. i hope the beach was cleaner than it is now
Thanks Peter
Peter
and it's not the first series of that kind of events either, noticed it for years now....
I thought your radiator was aluminim, not brass. Somewhere in the back of your mind, you may want to consider changing over to aluminum at some point...if you do indeed have brass.
As far as 200* running temps, that within range of safty,tho a bit warm.
Welcome to the forum. The picture of the Huey was taken when i was in the Blackpool/Kirkham/Whisham area this past jan.Perhaps you have seen it fly over your area,its the only flying Huey in the UK
I'll do a search for tom dewitts posts, Thanks
As to the huey question, no i haven't seen it
I'm down on the south east coast of the u.k. next to southend airport and do see some nice planes but not your huey i'm sorry to say.Regards peter
Ive lost it again on beaches here too lol
