LT1 hood
Old Sep 22, 2007 | 02:49 PM
Terry Lanham's Avatar
Terry Lanham
Default LT1 hood
I am restoring a 70 LT1. I have a hood that looks to be after market ( white glass). Will this hood be meet NCRS standards? If not, any body out there know what I should look for.
Old Sep 22, 2007 | 04:26 PM
wfo76's Avatar
wfo76
The judges will probably detect an aftermarket hood so if you are concerned about taking the points hit, a used factory or NOS hood is the only way to go.
Not sure how to tell an original LT-1 hood or if the 454 and LT-1 hood is different.
There is the Corvette Expo coming to Sevierville, TN on Oct 19-20, maybe you can find one there.
Old Sep 22, 2007 | 04:37 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
The later NOS hoods were a white grey color because they were made out of SMC. The original LT1 hood is the same as the big block but the big block hood is drilled for emblems.
Old Sep 22, 2007 | 08:08 PM
Terry Lanham
any suggestions on finding an original hood, is it a problem covering the holes on a BB hood.
Old Sep 23, 2007 | 08:58 AM
R1234's Avatar
R1234
You should be able to find an original hood. When you fill holes in fiberglass you have to be careful of shrinkage. The holes need to be glassed-in front and back side. If shrinkage does occur, you wind-up with small dimples in your paint.
Bryan
To LT1 hood
