15.5+ Volts - normal/acceptable?
Old Sep 28, 2007 | 09:04 PM
VCuomo's Avatar
VCuomo
Originally Posted by PeteZO6
That's simply not true for Corvettes. Starting in MY 1969, Corvettes came with an internal regulator. I offer as documentation the 1969 Chassis Service Manual covering the full Chevrolet line (pg. Specifications 12) and 1969 Stingray Guidebook by Rick Bizzoco (pg.174), as well as my 1969 convertible which has an internally regulated alternator. GM calls it the Delcotron 10-SI.
Pete
Both my '72 and '73 have internal voltage regulators.
Old Sep 29, 2007 | 12:42 AM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
New one is in. It measured 15.15V when I first started the car. I put 10 miles on the car and when I returned I measured the alternator at idle and it read 14.40V. Woot!!!
Old Sep 29, 2007 | 07:56 AM
kb2fzq's Avatar
kb2fzq
When you say you measured the alternator, you are checking the voltage at the battery, right? What is the voltage between the pos/neg posts, car running at idle? That is the voltage to be concerned with...if it's under 14vdc at the battery, you're good.
