A few more ??
Old Sep 25, 2007 | 08:50 PM
63_GrandSport's Avatar
63_GrandSport
Default A few more ??
I was thinking about putting side pipes on my 78 and I know they did not come that way but wanted to know what it would look like? Any one have a 78 with them on?
What is the easy way to get the turn signal switch out of the steering column? Is there a good picture of how the whole steering column goes back togetter?
And last but not lest I there a hiden build sheet in the car any where?
Thanks for the help
Adam
Old Sep 25, 2007 | 11:21 PM
FRSTR90's Avatar
FRSTR90
I ll take the 3rd question... There should be a tank sticker/build sheet on the top of the gass tank... becareful taking it off. I actually I recommend takin it off when you drop the tank. Half of mine is still up there!
With what sidepipes are you planning to go with? Hooker or Something similar to factory?
Old Sep 25, 2007 | 11:32 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
For your Steering column questions look here. Jim is THE recognized expert.
http://jimshea.corvettefaq.com/
There are plenty of guys that have sidepipes, IMO it's Hookers or stay underbody. For other reasons I have chosen to stay underbody, but if you get sidepipes then seriously consider getting SideShields. They were a vendor here, but I don't see their ad anymore.
Old Sep 25, 2007 | 11:44 PM
yel76low's Avatar
yel76low
Or you can go the cheap route with patriot shielded sidepipes. They're $200 from Jegs, including the heat shields. Obviously not the performance route... but that's what I'm going to be doing over the winter.
Do a search on them, several members have them and like them.
Old Sep 26, 2007 | 12:47 AM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
If you need to pass smog checks where you are side pipes may be a problem, as far as I know there is no company that makes sidepipes with cats in them, Thats why Chevy stopped offering them in 75 I believe.
Old Sep 26, 2007 | 03:23 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Another member solved that little sidepipe smog issue not long ago...
Old Sep 26, 2007 | 08:06 AM
pbcanney's Avatar
pbcanney
Default Dead Sea Scrolls for vettes
I've been lusting after side pipes myself, but I'm sure to be in the dog house if I drop 1500 - 2k on the Hookers I want.
Old Sep 26, 2007 | 08:45 AM
Durango_Boy's Avatar
Durango_Boy
Originally Posted by pbcanney
...but I'm sure to be in the dog house if I drop 1500 - 2k on the Hookers I want.
Women always get bent out of shape when you spend that much on good Hookers. Sometimes it's hard being a guy and lusting after the things we do.
Old Sep 26, 2007 | 01:40 PM
Jay-Dog's Avatar
Jay-Dog
I love Hookers. However, if I was paying for them, I'd probably pass. My vette came with a pair. Oh wait, your talking about exhaust?
Old Sep 26, 2007 | 07:21 PM
63_GrandSport
Thanks yall. I dont know what kind of side pipes I want but I do like the way they look I am looking at the page about the steering column to try to help me. I might try to get the build sheet off this weekend to see what all this car has.
Thanks again to all of you for your help
Old Sep 26, 2007 | 07:28 PM
RockyL32's Avatar
RockyL32
HAH!!! That looks just like the fart cans sticking out the back of some ricers around here. I always thought they did it too try and sound cool, now I know its to help save the environment
Old Sep 26, 2007 | 07:58 PM
jbowles49's Avatar
jbowles49
Default one more option
In reference to your sidepipe question, you can make your own using the available fiberglass replicas. Mine were painted with an aluminum color
and black and a muffler shop fabricated the exhaust pipes. I used hedman side exhaust headers. Very nice sound and no leg burns. Depending on how much work you are willing to do on your own it is a much less costly alternative to the Hooker setup. I purchased mine on ebay already painted so the cost was even lower.
Good luck
Old Sep 26, 2007 | 09:56 PM
63_GrandSport
Good luck
Do you have any pics?
Old Sep 26, 2007 | 11:26 PM
jbowles49's Avatar
jbowles49
Default no pics
Sorry, I don't own a digital camera however perhaps some other members have used these covers and have pictures of a similar install.
Old Sep 30, 2007 | 03:07 PM
jbowles49's Avatar
jbowles49
Default Side pipe picture
I now have some pictures of the sidepipes if you can tell me how to attach them.
Old Sep 30, 2007 | 03:28 PM
DR.Jay's Avatar
DR.Jay
I have side pipes on mine. I made mine myself for about $70.oo you can see them here with the covers off prior to pinting the car.
I am also using the fiberglass replica covers. The come un painted so the sky is the limit as to color. I painted mine black, and then added the yellow to the raised ribs later.
For supporting the pipes I made a bracket using an exhaust hanger with an intigrated rubber insulator strap. I welded the metal part of the hanger to the glass pack near the outlet, and welded a bolt to the frame to use as a stud. I trimed the insulator to length, and drilled a hole in it to hang on the stud, then secured with a fender washer, and a nut.
Old Oct 1, 2007 | 08:33 AM
1Z87L8's Avatar
1Z87L8
i have them on mine.
To A few more ??
