Fuel guage problem
Old Sep 29, 2007 | 10:09 PM
maddmickey's Avatar
maddmickey
Default Fuel guage problem
My 74 has not had a working fuel guage since I bought it. I put a new tank and sender in before I ever fired it(rusted out). The guage still didnt work so I got a used one. Turned the key on and after a few seconds it started to smoke!! Pulled it apart, I have 12v at the pink wire, brown ohms to the tank sender. Here is the funny thing to me, the sending unit post shows 0 ohms to grnd. Shouldnt it have different ohms depending on how full the tank is? Do I have a bad sending unit? Did I just have two bad guages? I dont want to get a new guage and fry it to. Any ideas??
Old Sep 29, 2007 | 10:58 PM
Bruce C's Avatar
Bruce C
Sounds like a pinched wire, you should have 88 to 92 ohms to ground on a full tank. Disconnect the tan wire at the sender and the gauge, measure the sender and the wire, the wire should be inifinite, sender somewhere above 0 ohms
